People running 4.88 gears
Discussion in 'Performance and Tuning' started by taco_man, Oct 12, 2010.
  1. Oct 12, 2010 at 11:41 AM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    What rpm range are you at when your doing 60 mph on your speedometer?
  2. Oct 12, 2010 at 3:14 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ya op you might want to add what size tires lol
  3. Oct 12, 2010 at 4:03 PM
    taco_man
    Austin
    Houston
    09 texas edition
    That's what I'm running with my 37s I just thought it seems a little high. I hope it will go down when I go to 40s
  4. Oct 12, 2010 at 4:09 PM
    taco_man
    Austin
    Houston
    09 texas edition
    The gear chart says it will be closer to stock configuration
  5. Oct 12, 2010 at 5:12 PM
    taco_man
    Austin
    Houston
    09 texas edition
    I just don't know how my truck will look with 11 inches of lift and 37s
  6. Oct 12, 2010 at 7:14 PM
    taco_man
    Austin
    Houston
    09 texas edition
    I want to run the swamped m16 since that's what I'm running now and it lasts forever on the road and is great in the mud but I'm gonna have to ditch the 18s and going to 20s or 17s if I want to go to the 40
  7. Dec 26, 2010 at 12:06 PM
    taco_man
    Austin
    Houston
    09 texas edition
    No not yet. I switched to the fabtech lift because my spindle lift was arough ride. But I should by spring time. Quick question how are you clearing your 37s? I'm having a little trouble with my 2.5 inch coils with the 6 inch drop down bracket. I put a .5 inch top plate spacer on but my upper a arm was completely maxed out.
  8. Dec 27, 2010 at 10:13 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    don't cut it just spend 10 minutes with the hammer and you're done.
  9. Dec 27, 2010 at 10:18 AM
    Jason'sLawnCare
    Try it when you are frustrated:D. Once you bend it a little it gets easier. I originally tried it with a rubber mallet to preserve the paint but it went no where. I had to use a decent sized hammer. A hammer for nails probably won't cut it.
    Here's mine and I'm not a big guy by any means.
  10. Dec 27, 2010 at 10:24 AM
    Jason'sLawnCare
    no problem. I could imagine the other way would be harder and this way closes the gap some to. Also it helps to remove the tire so you can get a bigger swing.
