People that have 4 door for familys
Discussion in 'Audio & Video' started by Guess2010, May 22, 2012.
  1. May 22, 2012 at 8:55 AM
    Guess2010
    Guess2010 [OP] Well-Known Member
    DAVE
    Saskatchewan
    2010 trd tacoma double cab
    Just a few dont tell the wife!!!
    ok so i wanna put either two 8" subs or one 10" behind the rear seat of a double cab.
    my problem is tho i need both outside child seat rings to still be used.
    Anyone got any pics of them still being able to be used.
    i can cut out the middle one.
    seem like ever sub box install they always take them out.
    doesnt anyone have little ones with a banging stereo??
  2. May 22, 2012 at 9:11 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Supercrewsound.com box with the deeper mounting depth 1, 2, or 3 JL audio w3's. That box will fit under the child restraint bar and bump plenty hard for the average person. I say get two 4 ignore versions of the w3's and a Kenwood kdc8105d amp wire to a 2 ignore load and call it done.
  3. May 22, 2012 at 12:04 PM
    Highspeed
    Highspeed Well-Known Member
    +42° 52' 21.69", -124° 32' 8.50"
    TRD off road
    A.R.E. cap
    Mr. Marv makes boxes that also fit under the bar that holds the child seat latch. You should have plenty of options, 2x8", 1x10", 2x10". Just depends where you plan on mounting your amps.
  4. May 23, 2012 at 6:20 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The Supercrewsound box will cover the hooks, you'll need to custom make your own box, or MrMarv is a good resource to, good quality, but costs.
    What also may work, haven't tried it myself, is to get a single sub box that normally fits on the drivers side and put it in the middle of the passenger side, then the passenger side hooks remain uncovered. Amp(s) can then go under the front seats, or slap a piece of mdf down low on the far passenger side for an amp.
