People who have done AAL or TSB spring pack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by white91formula, Jun 24, 2013.
  1. Jun 24, 2013 at 5:24 AM
    white91formula
    white91formula [OP] Well-Known Member
    Boston, MA
    05 6speed TRD OR
    what have you used for the U bolts ? Are the TSB leaf pack U bolts longer than stock ?
    Getting ready to put the TSB springs under my truck but need to get new U bolts still.
    Tried searching but couldnt really find a clear answer :confused:
  2. Jun 24, 2013 at 9:59 AM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Stock U bolts should be fine
    I did an AAL and re used mine, there is more than enough meat on them.
    If your worried, order some U bolt flips and call it a day
  3. Jun 24, 2013 at 10:01 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    AAL re-used mine.
    Or get a flip kit and have new super long u-bolts, and cut em down.
    edit: whoops he already said that, sorry, well... x2
  4. Jun 24, 2013 at 10:06 AM
    white91formula
    Boston, MA
    05 6speed TRD OR
    Stock UBolts have 110k on them so i am going to be replacing them... just wanted to make sure what I needed before i went to get the parts.
  5. Jun 24, 2013 at 10:23 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I would just get the diameter and buy some that are a little longer. I have not put a wrench on one but they looked like 1/2" to me. Of course I would not do that if it were me unless the ones on the truck are corroded or rusted. I just put springs on my boat trailer for the fourth time including the originals and have never replaced the u-bolts. Boat trailer does not ge near the use the truck does but it gets some abuse because of the lack of suspension and getting dunked in the lake.
  6. Jun 24, 2013 at 10:27 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Stock U-Bolts are fine for me with the TSB Pack plus the Toytec 1.5'' AAL.
