People with Defined Engineering SUA kits
Discussion in 'Long Travel Suspension' started by 6spd, Apr 26, 2012.
  1. Apr 26, 2012 at 9:43 AM
    6spd
    6spd [OP] Well-Known Member
    san diego
    2023 4x4
    What kit do you have and what shocks are you running for stock location? non stock location?
  2. Apr 29, 2012 at 12:49 AM
    6spd
    san diego
    2023 4x4
    your pics and feedback is greatly appreciated. do you do a lot of jumps even though you have no bumpstops in the rear?
    what were the differences when you had went from stock leaves to the SUA kit?
  3. Apr 29, 2012 at 2:42 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Jumping without bump stops (or bypass shocks tuned to act as bump stops) is asking for frame damage.
    Krish is just running those shocks as a tenmoorary set up so I doubt he is hucking the truck on them.
  4. Apr 29, 2012 at 2:42 AM
    Mxpatriot
    Temporary*, damn iPhone...
  5. Apr 29, 2012 at 1:52 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    mine ships out Monday and probably wont be installed for a couple months.
    I have been also contemplating whether to do a bedcage or just running the IVD new 2.5 shocks. Decisions, decision. I will keep the normal bump configuration not going to do to hyro bumps unless I run a cage.
    Krish, how much lift you running with the kit? Did you remove the 11th leaf or keeping it with the new heavier duty pack?
    Also are those kings off a RaceDezert FS post?
  6. Apr 29, 2012 at 2:16 PM
    08pretaco
    az
    Regarding the highlighted comment, if you were to throw on some bumps that install on the shock IE the daystar poly bumps...are you still asking for frame damage or do you really need to be bumped axel to frame
  7. Apr 29, 2012 at 7:36 PM
    Mxpatriot
    You need a bump between the frame and the axle. If you bump off the shock, you're asking a lot out of that little 2.0 (asking for a bent shaft IMHO).
    You could grab some day star regular bumps and drill holes in the factory bump pads on the frame and just bump off that or the time being (that's what I'm doing with me SUA/shackle flip for the time being)
  8. Apr 29, 2012 at 7:47 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    like this
  9. Apr 30, 2012 at 6:43 AM
    08pretaco
    az
    Thanks Chase, that's was the plan I was just curious about the other setup
  10. Apr 30, 2012 at 11:36 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    My Defined Kit is being istalled today :)
  11. Apr 30, 2012 at 12:49 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    :thumbsup:
    whoareyou133 likes this.
  12. Apr 30, 2012 at 3:42 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Pretty stoked, should be all done tomorrow. Can't wait for the Mojave run to test it out. :cool:
    Then all I have left for the forseeable future is the 16" triples and the tube work.
  13. May 1, 2012 at 10:38 AM
    Mxpatriot
    I want to see some Go Pro action of the defined kit in the whoops. I want to see how that leaf pack cycles.
  14. May 1, 2012 at 2:37 PM
    Mxpatriot
    It seems to me that the steepness of the arch of that pack, in order to use the stock mounting locations, is what is causing the bucking; and also what is keeping it from bottoming out.
  15. May 1, 2012 at 8:58 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    lol . you could tell that from just a video and knowing nothing else about the setup? im curious as to what your background is to validate your comments?
    heres a little more video of the kit in action, im over trying figure out the embed thing.
    http://youtu.be/Y1HlUyCvBJg
    and yes krishes truck needs more compression, less rebound and obviously more shock since hes running stock length shocks.
  16. May 1, 2012 at 10:38 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    IMO keeping the stock shock mounting points with anything but stock springs it backwards progress. Especially leaf springs need more compression than droop and unless you want your ride height really high, you will never get you potential and it will buck
  17. May 1, 2012 at 10:46 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  18. May 1, 2012 at 10:51 PM
    rcfreak201
    rcfreak201 Well-Known Member
    I dont know much about this but after thinking about it how would you get that compression with the SOA leafs? (Assuming that compression and uptravel is the same thing :eek:)The amount of uptravel is extrememly limited and IMO using a J66 deaver pack with longer shocks is kinda pointless because you just get more droop but what kills the tacoma is the lack of uptravel. Like you said to gain that you need alot of lift or SUA.
    So are you saying you would rather have a SOA pack with longer shocks or SUA with stock length shocks? if you had to do it in stages... school me please! :p
  19. May 1, 2012 at 10:56 PM
    Supermoto
    Landon
    Fallbrook
    Absolutely that what I am saying. Shock is such a huge part of the equation that no one figures for. Defined makes great kits and if anyone is having problems with the kit bucking or anything else it's the shock not the kit. Shock valving and placement is number one when it comes to ride.
  20. May 1, 2012 at 11:07 PM
    6spd
    san diego
    2023 4x4
    looking good. glad I posted this thread. looking forward to your progress, and I'm pretty sure, I'll somewhat follow your footsteps
    maarkymaark likes this.
