People with Defined Engineering SUA kits
Discussion in 'Long Travel Suspension' started by 6spd, Apr 26, 2012.
  1. Feb 11, 2013 at 10:02 AM
    #181
    Swetpants
    Swetpants Well-Known Member
    Tyler
    Surf city, ca
    2010 4x4
    It was a suggestion for a starting point for valving. As you know every truck will be a little different. Not to mention getting it right takes time. I would bet you will be satisfied if you went down to an 8 on rebound (I am). If you think about it adding weight will only really affect comp. The weight of your axel, tires, and rims affect the rebound aspect. As others stated in your thread it might not be dropping out fast enough because of the stiffer rebound. That and real hydro bumps, I think will have a profound effect. This is just my opinion though and I am no professional. All in all I have seen much worse. I have removed 0 leafs out of the 10 pack and have 0 complaints. Good luck.
  2. Feb 11, 2013 at 10:57 AM
    #182
    BradyT88
    BradyT88 Well-Known Member
    How much lift are you guys typically getting in the rear from the defined kit? I saw that the website says about two inches, but I would like to maintain my at least 3" of lift for when I go to larger tires.
    Any idea how the kit performs with a shackle flip and longer shackles? (I think the factory shackle is pretty ugly and longer shackles could give my that extra inch of lift)
  3. Feb 19, 2013 at 5:19 PM
    #183
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i got like 1" from 8 leaf and maybe 2.5 with the 11 leaf
    HEY SWETPANTS im pretty sure ive seen you on the 101n by pismo! pulling a trailer, i remember passing a truck just like yours and then i saw the rear bypasses haha.
  4. Feb 19, 2013 at 10:22 PM
    #184
    Swetpants
    Tyler
    Surf city, ca
    2010 4x4
    Hahaha, unless your truck is a time machine it wasn't me. I haven't been up in that neck of the woods in years. I have seen a truck identical to mine once as well, except it had fiberglass.
  5. Feb 19, 2013 at 10:27 PM
    #185
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Put more than that :smack:
    Byb127 likes this.
  6. Feb 19, 2013 at 10:37 PM
    #186
    anthony250f
    Anthony
    San Diego, CA
    I put a 35" toyo mt haha...i dont need more weight...it would bottom out even faster lol.
  7. Dec 11, 2017 at 7:21 PM
    #187
    anthony250f
    Anthony
    San Diego, CA
    This kit is not good in whoops...what do you do with your truck ?
    Byb127 likes this.
  8. Dec 12, 2017 at 7:15 AM
    #188
    anthony250f
    Anthony
    San Diego, CA
    I think I only got like 12” of travel from this kit...either way not very good. I’d rather go with like a dmz kit and do shock hoops under the bed.
    Coot83 likes this.
  9. Dec 12, 2017 at 7:37 AM
    #189
    anthony250f
    Anthony
    San Diego, CA
    They should!! It’s the same rear suspension. Thanks man!! It’s def a budget build but it gets the job done! Lol
    Dalandser and Byb127 like this.
  10. Dec 13, 2017 at 6:11 PM
    #190
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    defined does not make this kit anymore, but TC does and so does Archive Garage. I'm just waiting for Archive's new shackle kit and should be pulling 14" with the new shackles. currently only maybe 10" with the stock shackle.
    I have: u540/539 deavers (same exact springs as Defined), 14x25 RR kings, Archive Garage shock towers
    Byb127 likes this.
  11. Dec 14, 2017 at 4:35 AM
    #191
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Nice man, is that their SUA spring?
  12. Dec 14, 2017 at 6:54 AM
    #192
    Coot83
    Scottsdale, Az
    2012 Baja TX
    For the most part, 14 is the max underneath the bed. Some guys are using archive garage's 14 inch shock relocation for the rear so they don't need a bed cage and keep the bed sealed. Archive pretty much has you weld to a fixed location on the frame so the install is straight forward, but it will need to be welded.
    Byb127 likes this.
  13. Dec 14, 2017 at 1:24 PM
    #193
    Coot83
    Scottsdale, Az
    2012 Baja TX
    No problem man, hopefully it works out!
  14. Dec 14, 2017 at 5:29 PM
    #194
    S.B.
    Sean
    San Diego
    15 Taco
    Archive sells the same springs as TC and Defined, only thing that is their's are the shock mounts for 14" shocks and the new shackles they just came out with (I was in the first batch and have yet to get them, lol)
    Byb127 likes this.
  15. Dec 14, 2017 at 6:49 PM
    #195
    S.B.
    Sean
    San Diego
    15 Taco
    2.5x14 RR Kings from DSM
    Byb127 likes this.
