People with Defined Engineering SUA kits
Discussion in 'Long Travel Suspension' started by 6spd, Apr 26, 2012.
  1. Jun 16, 2012 at 5:55 PM
    #41
    Defined
    Defined Well-Known Member
    mike
    southern california
    thats why i recommend 2wd trucks have a slipjoint added to the rear section. the 2wd driveshaft works fine it just stresses the carrier bearing, not much more than stock springs do though.the whole driveshaft moves when the axle is cycled, just not optimal even in stock form . thats why pretty much only the 2wd guys have carrier bearing problems.
    the trans has plenty of slip yoke left at full bump and dosent bind at full droop.so shortening the shaft wouldent be a good idea.
    also you need to loosen the cb mount at ride height to center it after you install the kit.this alone helps alot with the longevity of the cb
    i wouldent change the angle , just get the ds modified and your fine. you can also get a used 4wd ds and swap the rear section out, get it balanced and your set .
  2. Jun 18, 2012 at 2:04 AM
    #42
    6spd
    6spd [OP] Well-Known Member
    san diego
    2023 4x4
    since this is a SUA thread, what do people think about the Giant SUA conversion for the 2nd gen? looks nearly bolt on minus the fact that you'd have to grind off the existing spring mounts.
    would that be able to install in stages like the defined kit, meaning be able to use the stock length shocks for a while? or would one have to immediately use longer shocks?
    ultimately, I'm thinking SUA, then bedcage eventually, but that period of time could be a year or so. what would be the performance differences between the giant and defined kits with stock length shocks, and with a bedcage and 16-18" shocks?
    same questions for the DMZ kit...
    just thinking out loud here...
    nevermind. found some snippets of what I was looking for in terms of answers(could be baised, but nonetheless, they are answers...)
    http://www.tacomaworld.com/forum/2nd-gen-builds/151774-rcfreaks-build-88.html#post4248066
    http://www.tacomaworld.com/forum/2nd-gen-builds/151774-rcfreaks-build-70.html#post3924255
  3. Jun 18, 2012 at 7:02 AM
    #43
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I'm sure you could use stock length shocks with the giant kit. You just need to get the correct length limit straps so you don't rip your shocks in 2.
  4. Jun 18, 2012 at 7:34 AM
    #44
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Limit straps and bump stops would have to be adjusted.
  5. Jul 29, 2012 at 9:55 AM
    #45
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Planning on having the kit installed sometime this month, August.
    I have a question regarding a bump stop set-up. I was thinking would it be possible to get the Wheelers rear super-bumps and weld that to the axle (or old spring perch)? It would be in the factory location and bumping off the same spot the factory bump would be on the frame.
    Would that work?
    Thanks
  6. Nov 30, 2012 at 3:19 PM
    #46
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    So I'm starting to do some research on LT's because I want to start moving towards a rear LT in the near future. But I want to do it in steps. Some people have said that I can get the Defined Stage 1 SUA Kit and use limiting straps until I can get a cage and longer shocks. I was looking at the Defined website and it looks like they have two kits, one that is $1380 and another that is $1650. I'm confused about what the difference is between these two kits. The $1650 one says that it only has up to 10" of travel while the cheaper ($1380) one says it has up to 15" of travel :confused:
    Can anyone enlighten me? I'm still a newb when it comes to all this suspension stuff...
  7. Nov 30, 2012 at 4:30 PM
    #47
    Bandwagon
    Bandwagon Well-Known Member
    Escondido/San diego
    Camburg long travel, full glass,
    The more expensive kit has stuff for bump stops
  8. Nov 30, 2012 at 4:38 PM
    #48
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    The more expensive kit is what is referred to as the "Stage 1" kit. This means it is designed to be ran with stock length/shocks in the OEM location. It includes Bolt-on Mounts for Poly Bumps to replace the factory ones.
    The Cheaper kit will require relocating the shocks to a simple shock hoop or bedcage and limit straps :cool:
    Go with the cheaper one.
  9. Nov 30, 2012 at 6:00 PM
    #49
    Drunknsloth
    Retribution
    South West
    Hmmm... So with the cheaper kit there is no way to do it in steps? How much do you think it would cost to have a shop do the install on one of these?
  10. Nov 30, 2012 at 6:12 PM
    #50
    theduck911
    Max
    Locked and Geared!
    Can you weld or have a friend that can?
    Then you can do it yourself. All that has to be welded on is the spring perches. Everything bolts in to stock hangers/shackle buckets.
    Otherwise probably $400-800 depending on shop etc.
  11. Nov 30, 2012 at 6:17 PM
    #51
    Drunknsloth
    Retribution
    South West
    Planning on learning this next semester between classes... Would it be better to just go strait to a bed cage, or go with shock hoops and then save up for the cage?
  12. Nov 30, 2012 at 6:54 PM
    #52
    theduck911
    Max
    Locked and Geared!
    Well then I'm sure you can handle it. But unless you're 100% sure of it or have a friend that knows it I would get shop to do it.
    Most people either go one way or the other. Depending on the use of their truck and future plans for the truck. Both serve the same basic purpose
  13. Nov 30, 2012 at 7:01 PM
    #53
    Drunknsloth
    Retribution
    South West
    Yeah maybe I'll ask around. I was assuming the bedcage would allow for longer shocks and more up travel. Is that false?
  14. Nov 30, 2012 at 7:02 PM
    #54
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    mainly it will allow for a longer shock that will be a closer match to the droop that the LT springs have
  15. Nov 30, 2012 at 7:05 PM
    #55
    Drunknsloth
    Retribution
    South West
    Yeah that's probably the route I want to go then.
  16. Nov 30, 2012 at 7:10 PM
    #56
    PLC721
    Patrick
    Chandler, Az
    theres not much point of doing hoops if you plan on doing a bed cage later, thats why i went with shock hoops, i knew that with what i like to do my truck won't need or see a bed cage
  17. Dec 1, 2012 at 10:46 PM
    #57
    Drunknsloth
    Retribution
    South West
    Hmmm... That means finding someone in my area who can do it...
  18. Dec 3, 2012 at 11:46 PM
    #58
    Defined
    mike
    southern california
    Defined Engineering SUA kits, Diff Skidplate, clamps and mounts are now SCORE Baja proven class championship winning parts. A full race season, 2 baja 1000's and we are still on the original springs with no maintenance other than visual inspections. now how many leafspring kits can say that? if these parts can survive being punished by LBR and Andy Bell. they can survive whatever you can throw at them.
    421054_3570099413943_1316701536_33448791_3f610a215b5e51ccd84182ca979f893c31725d23.jpg
  19. Dec 4, 2012 at 7:30 AM
    #59
    Bandwagon
    Escondido/San diego
    so what are the details of his rear setup? how many leafs, what type of shocks? any modifications to your kit or is it the same setup you sell?
  20. Dec 4, 2012 at 8:07 AM
    #60
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Defined SUA is legit.....saving up man!
