People with Defined Engineering SUA kits
Discussion in 'Long Travel Suspension' started by 6spd, Apr 26, 2012.
  1. Dec 4, 2012 at 8:43 AM
    #61
    Defined
    Defined Well-Known Member
    mike
    southern california
    its the same standard leafpack i sell to everybody and they are running bilstein bypasses in the rear . just a basic setup!
  2. Dec 4, 2012 at 9:18 AM
    #62
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Mike, I really want to get your Diff skid. Can you send me a PM with the price of one with the welds ground down and powder coated?
  3. Dec 4, 2012 at 9:56 AM
    #63
    Bandwagon
    Bandwagon Well-Known Member
    Escondido/San diego
    Camburg long travel, full glass,
    cool, just seeing if you had any secrets that youre not telling us.... haha jk
  4. Dec 4, 2012 at 12:32 PM
    #64
    6spd
    6spd [OP] Well-Known Member
    san diego
    2023 4x4
    why is this? stock location shocks can not be used for the cheaper version sua? and with bump cans(I think not, due to the nature of the shock being bottomed out, but that is me thinking out loud)? :confused:
  5. Dec 4, 2012 at 7:24 PM
    #65
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    The "cheaper" version is the "full LT version". The more expensive version is the 1/2 way there version, it is coming with extra parts to allow you to run stock shocks (extended bump stops that keep you from crushing your shock). That's why it costs a bit more.
  6. Dec 5, 2012 at 11:24 PM
    #66
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I know some people said that using the stock locations has it's advantages and disadvantages. I'm not doubting the quality of the product. So far I haven't seen anything negative about Defined, but what would the disadvantages of using the stock locations be?
  7. Dec 5, 2012 at 11:32 PM
    #67
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Less overall travel. Only nets about 10" with OEM location/style shocks. Reduced travel on both up and down travel.:cool:
  8. Dec 5, 2012 at 11:43 PM
    #68
    Drunknsloth
    Retribution
    South West
    Even the cheap kit that advertises 15"?
    Thanks for all your help man!
  9. Dec 5, 2012 at 11:56 PM
    #69
    theduck911
    Max
    Locked and Geared!
    It's 15" of travel with a Bedcage & 14" or 16" Shocks. :cool:
  10. Dec 5, 2012 at 11:57 PM
    #70
    theduck911
    Max
    Locked and Geared!
    Unless you're referring to using the Stock Leaf Hanger & Shackle bucket?
  11. Dec 6, 2012 at 12:04 AM
    #71
    Drunknsloth
    Retribution
    South West
    Yeah that's what I was refering too :eek:
  12. Dec 6, 2012 at 8:28 AM
    #72
    theduck911
    Max
    Locked and Geared!
    Well it is technically weaker as it' just stamped sheet metal. As far as I know there hasn't been any major failures as far as the mounts go.
    Adding a shackle bucket cross-member like the Defined one or similar is a key strengthening device.
    Other then that you should be fine. Basically just limited in droop by using the stock mounting locations :cool:
  13. Dec 6, 2012 at 8:36 AM
    #73
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I agree but disagree with your droop and factory mounting locations.
    Factory mounting location will yield 2 results.
    You can run a longer shock to get more down travel but that will affect your bump negatively.
    Respectively if you run a shorter shock you will gain bump travel but will take away from droop.
    So in theory you can run the stage one but proper setup for shock length will be key. You want more droop youll have to extend the bump stop closer to the axle. You want more bump make sure your properly strapped.
  14. Dec 6, 2012 at 8:41 AM
    #74
    theduck911
    Max
    Locked and Geared!
    I wasn't referring to shock length, that was covered previously. I meant using the stock/OEM Leaf Hangar & Shackle bucket limit droop, compared to DMZ etc.
  15. Dec 6, 2012 at 9:24 AM
    #75
    08pretaco
    az
    Sorry Max, should have followed yhe posts a little better :eek:
  16. Dec 6, 2012 at 9:31 AM
    #76
    Defined
    mike
    southern california
    so far i cant say anything negitive about using the stock leaf mounts , but i guess i am a little bias. i get the same overall bumptravel that the other kits out there get, but come up an inch or two short on droop compared to the others. its also a hell of a lot cheaper to install than traditional sua kits, can use your oem driveshaft and even the stock shock mounts if you want to sacrifice some travel . i could go on with the pros . but i cant think of any disadvantages. the oem brackets have been holding up great and with these trucks id prefer a riveted mount ,instead of welding to a heat treated frame. if there is disadvantages id like to hear them and the reasoning along with it.
  17. Dec 6, 2012 at 9:57 AM
    #77
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    You'll have to ask the Moncure brothers about the set up. They paid top dollar to have Tom Morris tune their suspension, so only they know.
  18. Dec 7, 2012 at 2:02 PM
    #78
    Drunknsloth
    Retribution
    South West
    Sweet. :thumbsup:
    Sounds good, I'll be in touch probably mid-next year.
    Now to decide if I want this kit first, or if I want to get a bullet bike first...
  19. Dec 12, 2012 at 6:13 AM
    #79
    08pretaco
    az
    What length rear brake lines your guys running?
    Just thought of the fact that I will need longer lines.
  20. Jan 1, 2013 at 12:06 PM
    #80
    Bobber Bill
    Los Angeles, CA
    You should be fine with almost any off the shelf extended line kit. I am running AP lines and have plenty of line left with this much droop.
    Has anybody had issues with the stock rear hangers/Defined shackles flexing and hitting the frame? I mean, with their shackle cross brace in place as well.
