People with Defined Engineering SUA kits
Discussion in 'Suspension' started by 6spd, Apr 27, 2012.
  1. Apr 27, 2012 at 9:24 AM
    6spd
    6spd [OP] Well-Known Member
    san diego
    2012 4x4
    What kit do you have and what shocks are you running for stock location? non stock location?
  2. Apr 27, 2012 at 10:18 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I believe any 10" shock will work in the stock location. It's capable of pulling 15" of travel so a 16" shock strapped to 15" will get er done!
  3. Apr 27, 2012 at 10:25 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    10" shock will probably bottom out metal to metal, stock replacement shocks are 15.83" collapsed, while a King 2.5x10" smoothie is 18.375" collapsed. That means the shock will bottom out 2.545" sooner than stock. No Bueno
  4. Apr 27, 2012 at 10:50 AM
    6spd
    san diego
    2012 4x4
    what is the 10" measuring? the stroke of the shock? the body of the shock? what does the OEM shock measure at?
    blackhawk - if a king 2.5x10 bottomed out at 18.375, are you taking into consideration the bumpstop?
  5. Apr 27, 2012 at 11:02 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    10" measures the travel of the shock ie the stroke.
    OEM specs are 15.830" collapsed, 24.290" extended, so 8.46" of travel
    Stock spec shocks bottom out after the bump stops strike. If you get longer collapsed length shocks, they may bottom out before you bump stops strike.
  6. Apr 27, 2012 at 11:02 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  7. Apr 27, 2012 at 11:18 AM
    6spd
    san diego
    2012 4x4
    cool. thanks for kicking down some knowledge on the shocks. I'm still curious on what people's setups are for this kit, though
  8. Apr 27, 2012 at 11:23 AM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Sub'd, I'm curious also
