Pep Boys suck Ass
Discussion in 'Suspension' started by GreatWhiteHype, Jun 5, 2009.
  1. Jun 5, 2009 at 10:41 AM
    GreatWhiteHype
    GreatWhiteHype [OP] Member
    Reno NV
    1st gen is the best gen
    deck plate, 5100's @ 2.5 in front, 2" aal toytec 5100 in rear
    So I finally found someone with a spring compressor to swap my 5100's (I was skeched out by all the injuries you guys detailed with the diy compressors). Pep Boys swapped both out for $42. I get home, and eagerly install the drivers side strut and it goes on great. Then I get to the passenger side and find that the bottom shock is off just slightly. So me being the brainiac that I am force the shock into the lca only to find that it still won't line up and now is suck. :frusty: My question is there any way to spin the shock without removing it?
    [​IMG][​IMG]
  2. Jun 5, 2009 at 10:49 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    BFH and choice words
  3. Jun 5, 2009 at 10:50 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    what he said....
    "If it don't fit, force it. If it breaks, it needed replacing anyways"
  4. Jun 5, 2009 at 10:52 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Brilliant! :D
  5. Jun 5, 2009 at 2:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Stick a 6" long (or longer) 3/8" socket extension in the lower shock mount "eye", and turn the shock until it lines up. It will be fine.
  6. Jun 5, 2009 at 4:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Oh my gawd, like I haven't seen that happen a gazillion times.
    You should be impressed they even got it lined up that CLOSE.
    I don't know how the 2nd gens are - but everytime I helped people with front lift installs on the 1st gens, I'd have to take a diagram to show them how to line everything up. More often than not, they STILL couldn't get it right even after I showed them the diagram!! 'Look dude, it still isn't right - FIX IT!
  7. Jun 5, 2009 at 5:22 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    This is like my install thread over again.....
    BRUTE FORCE AND IGNORANCE!!! Cuss a lot to.. Makes stuff work better
  8. Jun 5, 2009 at 8:25 PM
    sibanez
    sibanez Well-Known Member
    Camp Hill, PA & New Orleans, LA
    2002 4x4 SR5 XCab
    Leer camper Thule rack
    Easy fix. Get a 1/4" extension (6 inches or so) or a heavy duty screw driver and run it through the hole for the bolt and into the hole in the bushing. Then pry . . . you may also want to have somebody push down on the upper control arm.
  9. Jun 5, 2009 at 8:27 PM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    BFH is the way to go. That screw driver idea would work too.
