Perfect Gear Ratio
Discussion in 'Performance and Tuning' started by GUtaco, Apr 18, 2010.
  1. Apr 18, 2010 at 3:27 AM
    GUtaco
    GUtaco [OP] New Member
    Talofofo, Guam
    08 2wd taco reg cab
    I'm pretty sure more than one of you guys have changed your axle ratio on a 2nd gen. 2wd taco. I'd like to know what gear ratio you went with and how it turned out.
  2. Apr 18, 2010 at 3:33 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    you would get more info if you stated why you wanted to change R&P ratio. to comp for oversized tires. to take off easier pulling a trailer etc. 4 banger v6
  3. Apr 18, 2010 at 3:36 AM
    GUtaco
    Talofofo, Guam
    08 2wd taco reg cab
    I got the 2tr and would like to get a little more low end torque so i could kick off the line. Well its a street truck.
  4. Apr 18, 2010 at 3:40 AM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    i will let some1 that has actually regeared a 2nd gen give you his/her input. i have only regeared offroad vehicles and was for a totally different purpose. was only tryin to help you get the info you were after. try using the search function there is prolly a gear chart on here somewhere. Welcome to TW by the way
  5. Apr 18, 2010 at 3:41 AM
    GUtaco
    Talofofo, Guam
    08 2wd taco reg cab
    I appreciate your help Sparky4.0
  6. Apr 18, 2010 at 3:43 AM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    type in gear ratio on the search function there are like 10 threads to read that might have a little info on what your lookin for...NP. once ppl start wakin up some1 will answer your question better than i can
