Perfection/Duralast Clutch replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beechmon, Dec 14, 2012.
  1. Dec 14, 2012 at 8:19 AM
    beechmon
    beechmon [OP] Well-Known Member
    Justin
    New Jersey
    06 Tacoma 4 cyl 4x4
    Just bought, looking for ideas...
    I have a 4x4 06 toyota taco extended cab.
    Unfortunately burnt out my clutch with 110k miles on it.
    While i'm looking for clutches, they really range in price and was wondering what people went with. I see a lot of people going with centerforce which I've seen for about $400 and change...
    But when I call up a few places, Autozone just told me $99 for the clutch, clutch plate, all the barrings(except throw out) and allignor. I'm thinking this is almost too good to be true. Manufacturer is Duralast and has a 1 year warranty... Advance auto parts was at $130 for a perfection clutch.
    Any Advice?
    I do plan on hauling my 22 foot boat, like i have been, i'm wondering if this $99 clutch would still be able to do the work.
  2. Dec 18, 2012 at 12:06 PM
    beechmon
    Justin
    New Jersey
    06 Tacoma 4 cyl 4x4
    bump... no one?
  3. Dec 18, 2012 at 12:08 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    i would go back with the OEM if it was me
  4. Dec 18, 2012 at 1:58 PM
    MrTacoma
    MrTacoma Well-Known Member
    Tacoma Base v6
    None
    I work part time at an autozone ..I don't have a crazy amount of knowledge on cars I'm not even going to school for it but I do know from working there duralast stuff is ussally identical to the oem parts and autozone puts there parts cheaper on purpose because they don't cost that much to make anyway and to try to prevent u from going to the competition..to be honest my opinion might be little byiest because I work for the company that makes duralast..idk what track record on duralast parts are I just do know there ussally identical to oem..it doesn't matter what parts u put it what makes is how u maintain ur vehicle and drive it
  5. Dec 24, 2012 at 10:41 AM
    beechmon
    Justin
    New Jersey
    06 Tacoma 4 cyl 4x4
    yeah went with the autozone one... who can complain about less than $100 for it? now just need to find the time to install it.
  6. Dec 24, 2012 at 10:50 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just go with an OE replacement.
    You burnt your clutch out at 110k??!?!?
    most people go 200k+ miles on an original clutch.
    I'm at 121k on mine now without any sign of slippage. I tow stuff all the time.
  7. Dec 24, 2012 at 12:12 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I try to use a local clutch relining company when I can...
  8. Dec 24, 2012 at 12:40 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I have never had any luck with duralast parts from Autozone. I don't even buy anything from from autozone anymore. Chinese junk
  9. Sep 20, 2016 at 7:24 AM
    Kirvine07
    Kirvine07 Member
    Kyle
    VA
    08 4x4 Access Cab
    Wider set tires.
    I actually replaced my clutch recently. Got 141k on original. I was not original owner for first 50k.
    Regardless, I put the duralast clutch kit in to replace the OEM. (It was 130.... no brainer).
    Sounds like TO bearing is squealing now when clutch is depressed. Pretty noticeable, and the squeal goes away when clutch gets pressed in. It's only been a month since I had it put in.
  10. Sep 20, 2016 at 8:13 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Has anyone looked at the manufacturer stamping on the Duralast clutch? Some of the Duralast stuff is just rebranded OEM. It's possible it could just be a rebranded Luk or Aisin - which would make them identical to OEM.
