Performance air filter mod questions
Discussion in '4 Cylinder' started by BPachom, Apr 25, 2009.
  1. May 6, 2009 at 10:33 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^Next oil change. 4000kms. Wait a month or two.
    I hear it'll give me at least 34RWHP.
  2. May 6, 2009 at 10:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Keep me posted....To clean the sand, put it in your rear diff for 100 miles, or ........like........182Kms......:confused:
  3. May 6, 2009 at 10:40 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I heard that adding cat feces to it helps improve the consistency of the sand. Any truth to that?
  4. May 6, 2009 at 10:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm.......Not sure about that....I would go with Roofing nails.
  5. May 6, 2009 at 10:54 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Just to be safe I might put both in with a little CLR for good luck.
  6. May 6, 2009 at 10:55 AM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    opinions for sure....just trying to see if someone has anything other than that. The links were good info. But has it been determined that it's actually DONE something to a motor?:confused:
    One of the main reasons OEM filters are the way they are is to suppress intake noise to meet EPA guidelines. Of course they are there to filter the air...but to what levels are actually NEEDED. Any engineer types here that has experience with this stuff?
  7. May 6, 2009 at 11:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There are also resonators alon the intake track to supress the intake pulses.....It boils down to, more air flow thru a filter has to come at the expense of filtering efficiency. After I switched back to the OEM filter, my silica levels dropped to a very small amount, and my intake track was clean. Another thing about filters, the OEM filter has quite a bit of surface area......alot, actually, and flowes quite well. I had installed a vacumme gauge on a few of my engines, and a clean OEM filter doesnt pull any vaccume on the gauge. That tells me that the engine isnt feeling a restriction. FWIW, I tested this under WOT on a dyno.
