Performance and fuel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kyzer76, Feb 17, 2013.
  1. Feb 17, 2013 at 7:43 AM
    Kyzer76
    Kyzer76 [OP] Member
    Alberta
    2013 Tacoma
    3"lift one size bigger tires
    I have 20000kms on my new 2013 Tacoma and I feel it is under powered and my fuel economy at best is 16.8 miles per gallon. Does anyone have this problem if so what have you done to improve it.
  2. Feb 17, 2013 at 7:53 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Hi! Welcome to TW! I'm Also from Alberta. You seem to be past the break in period, milage usually improves around the 10,000km mark if its going to. There could be a number of factors, Lift kits and Larger tires take their tolls on these trucks as far as mileage is concerned. What all do you have modified on your truck?
  3. Feb 17, 2013 at 7:55 AM
    Kyzer76
    Kyzer76 [OP] Member
    Alberta
    2013 Tacoma
    I have a 3"lift is all
  4. Feb 17, 2013 at 7:59 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Your profile also says you have a double cab. So I'm assuming a 4x4 system & a V6 engine?
  5. Feb 17, 2013 at 8:04 AM
    Kyzer76
    Kyzer76 [OP] Member
    Alberta
    2013 Tacoma
    Yes that's right it's a trd
  6. Feb 17, 2013 at 8:06 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    16.8 MPG's seems average, maybe a little on the low side of average but still average. My suggestion is check your air filter, Alberta can be one hell of a dusty place if you're in the north section of it. And these trucks fuel economy drops like a rock above 110.
  7. Feb 17, 2013 at 8:18 AM
    Large
    Large Red
    16.8 MPG with a lift is pretty good..
  8. Feb 17, 2013 at 8:21 AM
    Kyzer76
    Kyzer76 [OP] Member
    Alberta
    2013 Tacoma
    Air filter is new and all I drive is hi way miles very conservative driver but I drive at 120km all the time
  9. Feb 17, 2013 at 8:21 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yup, Also you need to realize that if your using a softer type of shock, there is a lot more dampening of movement, meaning it works against you for fuel mileage on the hiway.
  10. Feb 17, 2013 at 8:25 AM
    Kyzer76
    Kyzer76 [OP] Member
    Alberta
    2013 Tacoma
    It's pretty bad my wife drives a 2012 chev Tahoe way more horse power way bigger unit and averages 23to24
  11. Feb 17, 2013 at 8:32 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yea, unfortunately the current engine in the Tacoma is very outdated, Pioneered and hit the market in 2004 I believe, which means it was in development and design at least 2-3 years prior ot that. It's old and innefficient by todays standards. :(
  12. Feb 17, 2013 at 8:48 AM
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    Not sure the elevation you're at but that will have an effect too. Also, winter months always produce lower MPG's.
    Not sure what part of AB you're in but we were in Banff/Norquay/Lake Louise for 10 days during Thanksgiving and that part of Alberta is one of the most beautiful areas I've ever been too. Can't wait to go back next year.
  13. Feb 17, 2013 at 8:50 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ♥ Alberta
