Performance chip
Discussion in 'Performance and Tuning' started by ahigginsdeca, Dec 31, 2008.
  1. Jan 1, 2009 at 12:40 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I agree. Thats what i first noticed, is that your sixty was a little high for the et. tenths on that sixty will exponentially increase your 660 and 1320. I'm sure you can squeeze more out of it.
    As far as their sanctioning, IHRA, NHRA or nothing, it is still a great track and they have invested quite a few millions into that surface. I remember about six years back when they brought in some people to diamond grind the top end so they could level it out a couple hundredths of a foot!
    Alright, ill stop hijacking this thread! :eek:
  2. Aug 21, 2013 at 3:53 AM
    duppers1957
    duppers1957 Active Member
    steven
    ukiah,california
    2006 preruner sr5
    throttle body spacer ,jba headers with flomaster.17"tires Volant cold air induction
    I found a chip called g-force performance chip kit for Toyota Tacoma for $69.00 and was wondering if anyone has tried it?
  3. Aug 21, 2013 at 7:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It is a trap to steal your money. Don't buy it.
  4. Aug 21, 2013 at 7:08 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Apparently Bully Dog has a system with a tuner in testing, I have not received a reply from them yet on whether it is a piggy back or flash system.
    http://www.autoanything.com/performance-chips/bully-dog-gt-t-toyota-tuner
    According to Ryan at auto anything, its a direct OBD-II port plug and play system, which should be interesting since Toyota is famous for odd production run firmware and hardware changes of their ECU's
  5. Aug 21, 2013 at 7:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Heard about that. I think that I recently deleted the PM about it though. Doh.
    Basically it discussed that the factory ecu was finally cracked and testing was underway.
  6. Aug 21, 2013 at 7:19 AM
    SoCaltaco65
    Well there is another that has cracked it as well, however I have a feeling that Toyota will raise a stink about this being on the market, they aren't too keen on customers being able to monkey with reliability to much.
