Performance chips/calibrators
Discussion in 'Performance and Tuning' started by DanGer, Apr 12, 2009.
Which programmer?
  1. URD MAF calibrator
    44 vote(s)
    32.1%
  2. Unichip Programmer
    31 vote(s)
    22.6%
  3. APR X-1 Engine controller
    53 vote(s)
    38.7%
  4. Other, specify
    9 vote(s)
    6.6%
  1. Apr 12, 2009 at 12:37 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    There have been a lot of threads recently on performance chips and calibrators so I figured to take a crack at an end all thread for information on these devices. So tell us which you have/like and why they work better than others.
    Bottom line to new guys, AVOID THE EBAY SHIPS that promise insane results. Here is a good explanation on these:
    Unichip
    APR-X1
    URD
  2. Apr 12, 2009 at 12:43 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    When I get to that point...The APR X-1 will be my programmer of choice...
  3. Apr 12, 2009 at 12:51 PM
    DanGer
    For anyone unfamiliar with programmers, mind sharing why you choose that one over the rest?
  4. Apr 12, 2009 at 1:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It's got the fullest range of features and controllability that I have seen...The Maf Cal from URD is great to re-map fuel but it does not allow management of ignition and it only adjusts the signal from the MAF Sensor if I understand it correctly...The X1 allows for complete control of the ignition and injection systems, as well as some system changes (cam timing gears, thermo) to help unlock every bit of power available.
    Xrunnit can probably explain it better than I can...cause he's used it.
  5. Apr 12, 2009 at 1:46 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Greddy Emanage Ultimate for me.
  6. Apr 12, 2009 at 2:01 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    :crazy::crazy::crazy:
    Mr Turbo over here...lol
  7. Apr 12, 2009 at 2:04 PM
    dually
    dually Low and slow
    haha. It has every tuning ability available! Its just a PITA to install LOL
  8. Apr 12, 2009 at 2:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm sure...I looked a a DAQ for my motorcycle and passed on it because of all the work to install it...and I don't really need it.
    But engine data tracking with GPS mapping and relational overlays are AWESOME!!
  9. Apr 12, 2009 at 2:17 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    For the items you listed in the poll... I rank them this way, with pros/cons. As you can tell, I am for the X-1, I have been running it for almost a year, and have been VERY pleased with the results
    First: APR X-1
    Pros: Designed by former TRD Engineers specifically for the 1GR motor. The X-1 controls the AFR/Spark table the same as any other high level tuning device, but works better with the stock ECU . The X-1 is self tuning, meaning you can add new mods, and the X-1 will retune based on what the sensors are reporting. X-1 features unique programs you won't find in any other unit. Engine Guardian - will put the truck into a limp mode when fueling becomes an issue and could threaten the motor. Launch Control - Used for the track or general shenanigans, makes launching the truck from a dig consistent and as fast as possible (with proper tuning). Unit is also plug and play and comes with exhaust timing gears and a 170* thermostat (will provide more hp based on your tune)
    Con: Timing gears are a tricky install. Cost is always a factor.
    Second: URD MAF Calibrator
    Pros: Takend from URD's website - Optimizing the fuel mixture for best power on stock or modified engines. Correcting MAF Sensor error caused by aftermarket intake systems. Remapping the fuel curve to compensate for high flow headers, exhaust systems, and cams. Unit is also much more affordable then any other tuning devices.
    Cons: Limted to AFR control (no spark control), tuning takes more effort when compared to the X-1. Not plug and play, splicing into factory ECU wiring is required.
    Third: UniChip
    Pros: Your able to control both Air/Fuel and Spark for a more complete tune. Unit is plug and play. More affordable then the X-1.
    Cons: Unit can ONLY be tuned by an authorized UniChip Tuning shop. Tuning can cost up around $300 a visit. Not self tuning, meaning you will need to retune for every new mod.
  10. Apr 12, 2009 at 6:55 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Worth every Dollar...:cool:
  11. Apr 13, 2009 at 9:44 PM
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    01' BSP S/C S-Runner
    S/C, URD fuel Upgrade, 2.2 Pulley, URD crank pulley, Truetrax locker, custom exhaust, plx, scangauge, D/P mod, amsoil drop in, 18x9.5 stern hyperblacks, ACA projectors, Grillcraft blackmesh, Performance Products valance, R/C Tails, B&M Short shifter, QA1 Coilovers all the way around, upgraded strut rod bars with heim joints, poly bushings everywhere lol, 1st model Streetacos bolt on four link!
    URD piggy back FMU not AFC
  12. Jun 9, 2009 at 1:05 AM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
  13. Jun 30, 2009 at 12:39 PM
    philinchains
    philinchains Member
    Mark
    San Antonio, TX
    13 Tforce Supercharged 4WD CrewCab
    TRD blower, Bilstein Baja shocks
    This is my 2nd unichip. I had one on a 2005 G35. My 08 Tacoma has JBA headers, AFE intake, AFE cat back, Y-pipe (no rear cats), and finally the unichip. I must say that with each upgrade, the most power felt was the rear cat deletion, and the unichip. The power it makes from 55mph to 80mph is insane. I had all mods on before the chip so I could have it tuned correctly.
  14. Aug 8, 2009 at 4:55 PM
    timofthehill
    timofthehill Timmy
    Timmy
    Caledon Ontario
    06 Prerunner SR5 TRD Debadged
    7" Suspension Lift, 3" Body Lift, 33's on 17's, K&N Intake, Magnaflow Cat-Back Exhaust
    I am still stuck on which chip. The APR-X1 cost to much for me... I want more power for a better price... URD has the maf sensor but its not a plug and play system. I don't want to be cutting into wires... The unichip I heard isn't the great.. Something to do with money to Hp ratio wasn't good.
  15. Aug 8, 2009 at 5:04 PM
    roxspin72
    NC
    Oh Yeah!!!
    URD MAF Cali, w/piggyback harness. $500ish + ship. Half the price of the X-1. :cool:
  16. Aug 8, 2009 at 5:10 PM
    timofthehill
    timofthehill Timmy
    Timmy
    Caledon Ontario
    What about the no spark control?
  17. Aug 8, 2009 at 6:02 PM
    roxspin72
    NC
    Oh Yeah!!!
    If you want to have your cake and eat it also, you got to fork out the dollars. Not to sound harsh, but that's reality. Performance & Quality = $$$:cool:
  18. Aug 24, 2009 at 9:27 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    :sadviolin: so true, so true
  19. Sep 7, 2009 at 7:36 AM
    clloyd
    clloyd New Member
    does the x-i allow changing of the throttle follower ?
    could not get an answer from apr themselves
  20. Sep 7, 2009 at 9:38 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Can you explain what throttle follower is?
