Performance Chips??
Discussion in 'Performance and Tuning' started by lostacrossfla, Aug 27, 2007.
  1. Aug 27, 2007 at 8:15 PM
    lostacrossfla
    lostacrossfla [OP] Member
    South Florida
    2010 TRD sport
    I just got an 07 tacoma and i was looking for a chip but i cant find any for the new ones..does anyone know where i can find one?
  2. Aug 27, 2007 at 8:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    basically, i think "chips" that actually do anything are a thing of the past......at least for the new tacomas. check out urdusa.com, as they have the maf calibrator which is probably what you are looking for( though it is a little pricey). hope this helps.
  3. Aug 27, 2007 at 8:41 PM
    lostacrossfla
    South Florida
    2010 TRD sport
    thanks for the help.
  4. Aug 28, 2007 at 6:20 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Check this thread for an in-depth discussion about "snake oil" performance chips, and how the URD maf calibrator is really the only product you'd want changing the stock settings on your taco.
    http://www.tacomaworld.com/forum/performance-tuning/2199-trd-cold-air-intake.html
  5. Aug 28, 2007 at 8:11 PM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    Has anyone heard if we might be doing a group buy on the URD MAF sensor calibrator?
  6. Sep 7, 2007 at 5:00 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Unfortunatley, no. Mine just came in... so it better not be any cheaper!
  7. Sep 7, 2007 at 5:25 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I am going to revisit the URD Group Buy question in the spring. If we have enough interest by that point, we will look into getting one going. Of course, if there is enough interest sooner, we will look into it sooner. ;)
  8. Sep 27, 2007 at 5:14 PM
    lkout4trucks
    lkout4trucks Active Member
    05 gmc canyon
    HP tuned, cat-back, gutted manifold, tons of interior and other stuff...
    is there any software for a full PCM(ECU) tune? i own a gmc canyon(chevy colorado) and i have my computer custom tuned. reallllly made a diff in performance.
    what kind of power are you all making from this maf calibration mod?
  9. Sep 27, 2007 at 5:19 PM
    maverick491
    South Jersey
    For a totally bone stock truck the MAF calibrator all by itself makes 15 additional REAR WHEEL horsepower. And it is user tunable, so after you add your CAI or header and exhaust you can re-tune it to make t he most out of those mods as well.
    Read about it here.
  10. Sep 27, 2007 at 7:59 PM
    lkout4trucks
    05 gmc canyon
    wow thats not bad at all if thats actual REAR WHEEL hp. from just a MAF calibration i dont see how you could tune it for an exhaust or something if its just from the MAF but im no professional.
    do your trucks have issues with speed limiters or torque management? can that tuner adjust shift points?? i think being a 2005 and a toyota it might take another year or so to get an actual tuner for you guys.
    base hp is what tho? pretty sure its more than the 5cyl colorado.
  11. Sep 27, 2007 at 8:10 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    base hp on the v6 is 236 or 238...one of the 2
  12. Sep 27, 2007 at 9:13 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    The calibrator essentially gives you control over the air/fuel ratio... exhaust/intake mods can alter the AFR so recalibrating the unit after adding those mods will give you the most power.
    The reason they are able to make more power on a stock tacoma is because they run rich from the factory, so you can tune the AFR right where you want it.
  13. Sep 27, 2007 at 10:22 PM
    lkout4trucks
    05 gmc canyon
    yeh gm does the same. actually they run wayyyy too rich. at least there is some form of tuning for the moment. there has got to be a company that does or is working on more detailed tuning for the tacos. if i do end up selling my truck and getting one i'll def have to look into it more. thanks.
  14. Sep 28, 2007 at 12:19 AM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    what are you expecting to see as far as "more detailed"?
  15. Sep 28, 2007 at 8:36 AM
    lkout4trucks
    05 gmc canyon
    heres from the HP tuners website:
    Engine
    * EGR, Air Pump, COT Enable/Disable and controls
    * Rev Limiters, Idle Speed and characteristics
    * Throttle Follower and Cracker
    * MAF Tables, Main VE and Cranking VE
    * Power Enrich fuel controls
    * Closed Loop/Open Loop characteristics
    * Injectors
    * Spark Advance and Retard
    Engine Diagnostics
    * MAP Error Values
    * MAF Error Values
    * Misfire Values
    * DTC's
    Transmission
    * Shift Speeds
    * Shift Firmness and Time
    * TCC Parameters and Tables
    * C.A.G.S.
    Transmission Diagnostics
    * Trans Slip Test Conditions
    System
    * PRNDL Flag
    * Fan Type Select
    * VATS
    * Fan On/Off Temps
    * A/C Parameters
    Speedometer
    * Speedometer
    * Speed Limiter
    its pretty much a full tune. i dont do the tuning myself i have a friend who does mine so hes the knowledgeable one on the subject but anyways im just surprised there isnt a more advanced tuner for the tacos. like i said, im sure one will come out soon enough.
  16. Sep 28, 2007 at 10:30 AM
    freak21s2k
    freak21s2k New Member
    how much does the MAF caibrator run? probably not cheap huh?
  17. Sep 28, 2007 at 11:24 AM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    I would highly doubt anything like that will be coming out soon...
    reason being is that there really wouldn't be much of a point to make changes to a lot of things on that list. Unless you're going forced induction, all you really need for the tune is to control fuel. The ECU is already controlling/monitoring everything else on that list and if a problem arises, it'd let you know by setting a check engine light
    not really bad at all, $228
    http://www.urdusa.com/product_info.php?cPath=66_72&products_id=1260198051
  18. Sep 28, 2007 at 4:19 PM
    lkout4trucks
    05 gmc canyon
    yeh. i have had most of those changes done to mine. the program is $800 but my friend charges $50-100 for his time and then another $100 for the rights to tune your VIN through HPtuners.
    for the power you guys are seeing $228 is a good price tho
  19. Nov 3, 2007 at 9:38 AM
    divetaco
    divetaco Member
    taco TRD 4x4 bare stock
    stock
    has anyone ever tried a ACR performance chip off of ebay. or is this just Bull
    I have a 2008 4.0L taco
  20. Nov 3, 2007 at 10:32 AM
    The_Hodge
    SC
    any performance "chip" for the new taco's dont exist...the things they sell on ebay is a lil plastic box w/ resistors in it and wires coming out of it...yet another waste of money
