Performance chips
Discussion in 'Performance and Tuning' started by Hrules56, Jul 28, 2016.
  1. Jul 28, 2016 at 2:02 PM
    Hrules56
    Hrules56 [OP] New Member
    Hunter
    2015 black Tacoma 4.0 TSS
    Lift kit and off road tires and rims
    Hi all, I am looking for a good performance chip to put in my 2015 TSS yota 4.0 v6. I am looking for something that will help my gas mileage out a good bit without messing up any of the computer problems. Also will need it to pass inspection.
    Thanks!
  2. Jul 28, 2016 at 2:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    As far as I know, there's no good options for our trucks. Pretty much no one on here runs one and the ones that have say it's useless.
  3. Jul 30, 2016 at 9:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Unichip, but you have to also get the package to self tune it.
    URD UCON, which is currently only available for their s/c kits, but should be available for regular purchase in a few months.
  4. Jul 30, 2016 at 12:01 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    If the Unichip system can be self tuned could it be altered to work for the 4 cyl, or is that too much of a leap?
  5. Jul 30, 2016 at 4:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No idea. You have to look up your year model compatability.
  6. Sep 1, 2016 at 11:06 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    There is no chip to increase MPG only power.....
    As you reduce fuel you reduce power.....
    You could get the uni chip and just advance the timing but that's a lot to spend just to advance the timing and my net you the same MPG with better performance....
    To maximize MPG leave the intake and exhaust stock.
    Synthetic fluids oil and gear fluid...
    Iridium tip plugs, (don't start)
    That will get you about 1 mpg... and that about all it's got.... I went from 18.8 to 19.9.... Then I put on larger tires 17 mpg...
    Stick to street tires or newer tires, some tires eat more gas as they wear out...
    If you lift it keep the nose down a little, don't lift the front higher than the back...
    Run 87 octane if your not towing or half tank of 87 octane....
    There are a few intakes that help get more cold air like a snorkel and they can help....
  7. Sep 1, 2016 at 11:13 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    Both the urd maf cal and uni chip work good but they won't increase mpg only increase power but use more gas....
    With my unichip my power map gets 10 mpg off road my overlanding map gets 14 mpg off road they both get about 16 on the road, I think my tires are wearing out because I used to get 17 on the road with 32 and a 2 1/2" lift....
    I just put on new 285 70 17 ST Maxx tires so will see what happens now....
  8. Sep 2, 2016 at 10:30 AM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Shr133 are you just both the URD MAF cal, and the uni chip together?
  9. Sep 16, 2016 at 10:59 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    I started with the maf cal, and really like the way it controls the fuel....
    Then I add the Unichip and ran both until I got familiar with the unichip...
    Now I'm running just the unichip....
    Both seam to control the fuel about the same... Unichip gives more control, finer adjustments, timing, multiple maps and faster to change maps....
    Either one will only improve power and drive ability not MPG...
  10. Sep 17, 2016 at 9:03 AM
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Will the uconn give me the same mpg's but more power??
  11. Sep 17, 2016 at 9:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Technically, it can. Due to a refined tune over OEM. The a little timing improvements, better cylinder evacuation with the exhaust cam gears, and better open loop afr's.
  12. Sep 17, 2016 at 9:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your driving style, still plays the biggest role. How much drive time you spend in open loop versus closed loop. Open loop gph will be reduced versus stock because of the better afr's. However, with the UCON, it is effectively always in closed loop feedback mode. Ehich makes it more consistent.
  13. Sep 17, 2016 at 10:09 AM
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    I know I need to get some sort of tuning device as I have intake, intake manifold spacer, headers, ypipe, and a custom cat back and plan on adding a 70mm throttle body and with no tuning what so ever I'm missing a lot of power. Just don't want to get something have even shittier mpg..
  14. Sep 18, 2016 at 9:48 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    The maf cal is cheap, mpg will drop but if it's not a daily driver, you won't care, fixing the fuel will make the truck run MUCH better.......
    But yeah it's time you do something to take advantage of your other mods, you will be happy you did....
    I'm trying to make a mpg map with the unichip but not working so far, it's better than my power map but still not good... just about 16 on the hwy with a lift and 33s... trying to back to 17 plus.....
  15. Sep 18, 2016 at 9:53 PM
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    It is my daily driver and currently get 400km to a tank 18mpg in city so roughly like 15-16mpg USA? I was thinking about doing the maf cal but was thinking of just going straight to the uconn for its self tuning feature since I know absolutely nothing about tuning but I do know I really need something :p
  16. Sep 18, 2016 at 10:05 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    So you're getting the same MPG as me with the tuner so maybe it will stay around the same....
    the ucon is the best way to go, but the most work to wire in......
    With the maf cal the may have a map for you to get you real close....
  17. Sep 19, 2016 at 5:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    UCON for his will plug right in. His is an '07.
  18. Sep 19, 2016 at 8:12 AM
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Most difficult part will be the cam gears right? I already have the colder thermostat installed also.
  19. Sep 19, 2016 at 9:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It can be for some.
  20. Sep 19, 2016 at 9:46 AM
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    I'm sure I could figure it out with some help from my friends... Guess I will start saving for the uconn!
    shr133 likes this.
