performance clutch
Discussion in 'Performance and Tuning' started by JakeMan, May 23, 2009.
  1. May 23, 2009 at 1:16 PM
    JakeMan
    JakeMan [OP] Alfred E. Neuman
    san francisco
    06 Prerunner
    jba headers-K&N intake-urd shortshifter
    does anyone have any input on this subject?stage 2 or stage 4
  2. May 23, 2009 at 1:28 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    It is stronger probably.
    Well, it doesn't take much to beat the stock clutch...
  3. May 23, 2009 at 1:34 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    I just installed a Stage 4 in my Xrunner a few weeks ago. I love it!!!
  4. May 28, 2009 at 4:49 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    If you don't race or have some sort of custom setup (Like a turbo) your stock will be fine go with a stage 2. I have a stage 2 and mine is fine. I do a lot of towing (5000lb trailers) I have headers, k&n and custom exhaust. I went with these guys and saved a lot of money. http://gripforce.com/store/ there stuff is good quality too I have had no problems with it
  5. May 28, 2009 at 4:51 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Someone mind breaking it down barney style on what this does exactly?
  6. May 28, 2009 at 5:23 PM
    jaxchrisfla
    flooriduh
    lots
    I dont see our clutch on their page?
    On exactly what does, the clutch? You replace the stock clutch disc and pressure plate for something stronger, and of a different material for better grabbing power. If you tow, a better clutch helps the transmission handle heavier loads. If you race or run big power, the stock clutch will start to slip because to much torque is being applied to the stock clutch disc, and it cannot hold anymore. Also, the stocks are known for separating.
  7. May 29, 2009 at 1:14 AM
    matthew5olson
    matthew
    pittsburgh, PA
  8. May 31, 2009 at 3:14 PM
    Marazzito
    Marazzito Well-Known Member
    Dublin, CA
    07 DC TRD Off-Road 4x4
    TRD Exhaust, AFE Cold Air Intake, URD Short Shifter, OME 886 HD Lift OME Rear Springs With XL... TRD Supercharger Coming Soon.
