Performance Engine Build
Discussion in 'Performance and Tuning' started by NfiniteZERO, Apr 14, 2014.
  1. Apr 22, 2014 at 5:01 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I like how this man thinks! But everyone knows wedding gifts are exclusively for the wives... :p
  2. Apr 22, 2014 at 5:07 PM
    NfiniteZERO
    NfiniteZERO [OP] Well-Known Member
    Matthew
    Boise, ID
    2013 Double Cab TRD Sport
    AVS BugFlector and Vent-visors, Wet Okole seat covers, Extang Trifecta Signature,
    Haha! Don't think I can get somebody to pony up that kind of cash for a wedding gift though. Though, I'm sure someone will get the case of beer and Oreos I put on the Target wedding registry. :D
    Going to be reading through your build thread - focusing mostly on the turbo side of things. Think I might have a question or two by the time I'm done. :thumbsup:
  3. Apr 23, 2014 at 9:18 PM
    NfiniteZERO
    Matthew
    Boise, ID
    Tor, I figured I'd ask you this since you've acquired a few engines over the course of your build. And I've got a couple days to go junkyarding...
    Would it be prudent to just focus on trying to find a Tacoma 1GR-FE or would I be safe about broadening it out to include the 4Runner and FJ Cruiser 1GR (single VVT-i) for trying to get a working core or long block?
    Also, how much of the 1GR did you (or importantly - can someone) assemble without having to go to the machine shop? I know it's unavoidable, but I really want to roll up my sleeves and do as much of the work as I can building this engine :D
  4. Apr 24, 2014 at 4:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The '03-'04 4Runner engine is the earliest that you want to go. But its intake cam gears and intake cam sensors are different that yours. Then anything from the other platforms, which is only single VVT-I. The dual VVT-I requires a different ecu to run properly, plus is a different design on the bottom-end as well.
    Depending on what all tools you have, you can do a lot of the assembly yourself. But for the machining and what not, you will definitely need a shop to do so. To make sure your clearances and tolerances are proper.
    I have never installed valves, guides, springs, or retainers in the heads. I have also never installed oversized valves. I left that to the machinists. Factory bucket shims and cams, all the time. Nothing to it. Factory bottom-end, all the time. That is easy.
    Checking aftermarket parts, and having to deal with possible machining differences.....I left that again to the machinists. Just safer.
    Dezod, and LC Engineering are fast, relatively. Compared to Darton. Both of their prices are even a little better than Darton's. Just need to do some calling for quotes, when you're ready. As far as attaching the heads to the block, and final assembly, you can have them leave that you if you like. Made me feel more apart of the build, from LCE. ;)
  5. Apr 24, 2014 at 4:51 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    To go more in depth with Ti, there are several manufactors that implement titanium for several of the rotating componentry in engines of production cars without needing rebuilds and have very long life. Race engines all have rebuild times like that regardless of materials.
  6. May 6, 2014 at 12:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any updates?
  7. May 7, 2014 at 8:40 PM
    NfiniteZERO
    Matthew
    Boise, ID
    Afraid not. Been too busy with work, wedding planning, and being flat broke. :(
    Probably won't get any headway on it until fire season is done here in the West.
  8. Aug 24, 2014 at 9:58 AM
    NfiniteZERO
    Matthew
    Boise, ID
    What a long strange trip this has been. Last couple of months have been crazy!!
    Been reading through my notes and catching up with everyone's build logs. The more I read, the more I'm talking myself into a turbo build.
    Sadly, I just don't think it's going to happen soon enough. So when I do get underway on this project, it will probably be in my build log (once I get one going).
