Performance Exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wesplains, Jan 27, 2015.
  1. Jan 27, 2015 at 7:04 AM
    wesplains
    wesplains [OP] Well-Known Member
    West
    Middle of USA
    Tacoma TRD Sport
    SnugTop, Aries Stealth Bull Bar, OEM Bed Mat, Wet Okole Seat Covers, Husky Floor Mats, OEM Cab Rack, Amp Bed Extender, VooDoo Bad Brackets with Cargo Basket. Yakima racks on cover. MagnaFlow Muffler, KC Running Lights, Console Vault, Dash Cam, Side Moldings, UltraGauge
    Does putting a different exhaust on cause problems with the MAF?
    I am getting ready to put a MagnaFlow on my DCSB 2014 V6 and happen to see here someone mention it.
    Will it affect my warranty?
  2. Jan 27, 2015 at 7:06 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Better off just putting a new Magnaflow muffler on. Your catback is perfectly fine, no other benefits to replacing the whole thing. Warranty issues I highly doubt it.
  3. Jan 27, 2015 at 7:12 AM
    wesplains
    West
    Middle of USA
    Tacoma TRD Sport
    Unchained, thanks. That is what I get for posting on 2 hours of sleep. The muffler/pipes is what I am doing. Staggered to the computer and read a post on exhaust/MAF and did not think it though.
    Disregard, back to sleep.
  4. Jan 27, 2015 at 10:49 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    No MAF or warranty issues. Straight pipe to muffler is stock size (ruling out the "scavenging issues" myth). Muffler to tip is larger than stock. Benefit of buying the kit is you can DIY without needing a welder and it's easily removable if you sell or have a change of heart.
  5. Jan 27, 2015 at 6:04 PM
    wesplains
    West
    Middle of USA
    Tacoma TRD Sport
    Thanks all.
  6. Jan 27, 2015 at 6:08 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    ur golden.............. I have to second the add a muffler to stock tubing unless its corroded, its already mandrel bent and large enough for our needs until force fed.
    ALSO, the last time I bought a cat back (URD 3") the thing leaked until I had the slip joints welded. Theres just no better way IMHO
    FWIW, did u know u could slip a soda can thru a 3" exhaust?
  7. Jan 27, 2015 at 7:11 PM
    MadDaddy
    Many & varied
    Re: slip joints.
    They will leak. It's an easy fix. Pretend, imagine (or even practice) by slipping two drink straw ends into each other. Blow water through. Some will leak at joint. Wrap tape across the joints like a bandaid on a finger. This will seal the joint and keep from leaking.
    Easy fix with this stuff called Tiger wrap. It's maybe $4 at the auto parts store. Once you have everything in its final position, cut a strip of Tiger wrap long enough to go around the pipe once and an additional inch or two for over wrap. Don't do any more than this. You want the clamp to fit over this wrapping. After wrapping, squeeze it tightly to bond with the pipe. Clamp everything down and drive for 20 minutes. The heat will bond the wrap to the joint and seal it up :)
  8. Jan 29, 2015 at 6:36 AM
    MadDaddy
    Many & varied
    I remember getting in trouble as a kid because I hid all my eggs in the tailpipe of a lifted Bronco at a community Easter egg hunt. They fit so perfectly! I was a kid, what did they expect?
  9. Jan 29, 2015 at 10:43 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
