Performance gain or not?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssjostrom1980, Feb 13, 2010.
  1. Feb 13, 2010 at 4:41 PM
    ssjostrom1980
    ssjostrom1980 [OP] Taco Love
    Phoenix
    1998 SR5 4x4 v-6 5 speed
    I have put a K&N Air intake, 1500 series bilstein shocks set at 2.5, with a procomp add a leaf to the rear springs giving 1.5 inch lift to the rear. Kenwood Excelon Deck with USB Port 4.0 V Pre Outs! Infinty Ref 4 channel amp for mids and highs Infinity Kappa Perfect component 6.5 in the front and kicker 6.5 two way in the rear. Alpine mono amp for 2 kicker 10 inch competition Subs in a custom Tacoma box. Gold Plated battery Terminals. BFG All Terrain 31's.
    I have a 1998 Toyota Tacoma v-6 4x4. I recently replaced the rear leaf springs with some from a 2001 TRD and added new bilstein 5100 series shock, before installing the newer springs I added a pro comp add a leaf to lift up to 1.5 inchs. I also replaced the front coils with those from the 2001 and used bilstein 5100 series struts set at 2.5 inch lift. My question is will this increase the offroading performance of my truck or possibly decrease it? My friend is telling me that the struts will have less travel since they are set at 2.5. Also how important is it to lower the front diferential?
    Thank you! :cool:
  2. Feb 13, 2010 at 4:46 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Well I believe that you have now less down travel bc your preloading the spring with the shocks. But not sure how much you will loose.
    But at 2.5" you should be fine not dropping your Diff. But anything will help lessen the strain on them. I would still do it at 2.5" lift.
  3. Feb 13, 2010 at 4:49 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    also nonTRD coils ride better than TRD coils...
  4. Feb 13, 2010 at 4:54 PM
    ssjostrom1980
    Phoenix
    The front differential should be dropped an inch right?
  5. Feb 13, 2010 at 4:59 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  6. Feb 13, 2010 at 4:59 PM
    ETaco23
    Evan
    PNW
    yeah, get the 1" diff drop. It will help....
    And yes to what mike said... your better choice will be to get some OME coils, and set your 5100's to 0, and get some 882's or whatever will give you a 2.5 or 3" lift. That would keep your Travel about the same If not give you more.
    (Just a suggestion though)
  7. Feb 13, 2010 at 5:08 PM
    ssjostrom1980
    Phoenix
    Cool!! Thanks guys!! when you say get some 882's can you elaborate I have never heard of those...
  8. Feb 13, 2010 at 5:21 PM
    ETaco23
    Evan
    PNW
  9. Feb 13, 2010 at 5:23 PM
    ssjostrom1980
    Phoenix
    Thanks again I will check them out and see what its all about.
