performance programmer
Discussion in 'Performance and Tuning' started by dtay4197, Oct 21, 2015.
  1. Oct 21, 2015 at 8:26 PM
    Springs719
    Springs719 Well-Known Member
    Brett
    08trdoffroad
    I'm running the mk3 stage 2 an very happy with it. Urd is a great product an with the ucon it will let you know when you hit red line as the check engine light will flash telling you to shift gears. An if you running a automatic think about getting a valve body upgrade. But as far as getting good gas mileage I'm pushing 400 miles to a tank cruising like a grandpa. But by you just adding the uncon with no supercharger I'm pretty sure your gas mileage will jump as well with a little hp. Good luck with your choice.
  2. Oct 21, 2015 at 9:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    5500 is OEM redline. 6200 is the raised redline for most N/A tunes. 5800 for F/I tunes. With the URD UCON. A lot of experience behind those #'s. Both on stock internals. You can always have it changed though. URD dyno'd their stroker engine at around 7k rpms. To see what the graph would look like. Then dialed it back for every day usage.
    Warriordinghy, a big roll of seran wrap from the grocery store. Not a "bunch" of ATF. Just a little. Then rotate the crank with a wench to get it to cycle the rotating components. I use Lucas Oil Heavy Oil stabilizer (the sticky stuff) and Redline Oil assembly lube.
    thewarriordinghy and Lord Helmet like this.
  3. Oct 26, 2015 at 4:47 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    :laugh: Never a dull moment in these type of threads. Almost reminds of the fuel pump thread awhile back :laugh:
    Rock Lobster likes this.
  4. Oct 26, 2015 at 4:59 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    Sounds good. Am I reasonable, or paranoid with my concerns?
  5. Oct 26, 2015 at 5:37 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    :rofl::rofl::rofl::rofl:
    thewarriordinghy likes this.
  6. Oct 26, 2015 at 5:49 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    He appeared... And I barely made it out alive
  7. Oct 26, 2015 at 6:00 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    If you say supercharger...ever...anywhere...a lobster will appear :rofl: :rofl: :rofl:
    and before he can troll "If you mention URD, fanboy blah blah blah"
  8. Oct 26, 2015 at 6:08 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Y not be a fanboy.. That y-pipe made my truck louder...
  9. Oct 26, 2015 at 6:41 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    But with top end gains?
  10. Oct 26, 2015 at 6:56 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    your just gunna unbolt the exhaust....
  11. Oct 26, 2015 at 7:53 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Running open headers.... ol' school hot rodder trick :thumbsup:
  12. Oct 26, 2015 at 7:55 PM
    Lord Helmet
    Nick
    '24 X3 M40i
