Performance Testing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tech708CC, Aug 9, 2021.
  1. Aug 10, 2021 at 11:47 AM
    #41
    Tech708CC
    Tech708CC [OP] Well-Known Member
    2020 trd off-road
    2020 is350 is listed at 311hp
    The rav4 and sienna van is 296 I think
    Junkhead likes this.
  2. Aug 10, 2021 at 11:49 AM
    #42
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    i was referring to I4................
  3. Aug 10, 2021 at 11:51 AM
    #43
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dude this is not a youtube advertising site for ad clicks. Good write up but the reason nobody has shown up in a Tacoma is because... nobody really cares. If I want to go fast for Tacoma money I will get a sports car. If I want to go fast for a bit more you can get a used Hellcat for around $60K. You are passionate I will give you that.
    coopcooper likes this.
  4. Aug 10, 2021 at 11:51 AM
    #44
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    They (Toyota) detuned the 3.5 from the Lexus models to gain lowend torque. Which is needed for a truck.
  5. Aug 10, 2021 at 11:52 AM
    #45
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    But the Lexus makes more tq at the same rpms.:notsure:
    Dawelda and Tech708CC[OP] like this.
  6. Aug 10, 2021 at 11:59 AM
    #46
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    OP, I appreciate the work you shared with us. I have one point of constructive criticism. I think the post would be more approachable if you either replaced the abbreviations with the full name or added a legend at the bottom giving them definitions.
    EDIT: it also was not clear to me until after reading the whole thread whether you were tuning the ECU or only adding aftermarket mechanical parts. Did you use vftuner? Did you start with a stock tune or one already available from ovtune or someone else?
    Tech708CC[OP] likes this.
  7. Aug 10, 2021 at 12:04 PM
    #47
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    You have to work on that 60' time if you want to go faster , try and get down into the 1.9x's or even better get into the 1.8x's
    Those Dragy's are nice , I've got one I use for my Camaro
    Also FYI ... every 200lbs removed is worth a tenth ( faster in the quarter or eighth mile )
    Tech708CC[QUOTED][OP] likes this.
  8. Aug 10, 2021 at 12:06 PM
    #48
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Because that's where the Toyota engineers programmed his taco to operate...
    I agree its not a good place to be. That's why so many are interested in tuning the transmission to move down a gear or two.
  9. Aug 10, 2021 at 12:08 PM
    #49
    dunlap837
    2018QSDCLBSR5
    OP awesome post, love to see this kind of stuff.
    Tech708CC[OP] and Junkhead like this.
  10. Aug 10, 2021 at 12:10 PM
    #50
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    Road Dog,
    No issues on driving lessons, lol. But I’m not in that 1100-1200 rpm range all the time, just a statement that is at the “peak” of its worst stutter/misfiring or whatever label we put on it.
    Most of my driving is a mix of back country roads where speed limits are 35-60 MPH. So my rpm’s are mostly 1500-1700 range. But if behind traffic and during braking and speeding back up or simply feathering gas to keep spacing I’m in low rpms a lot and experienced this characteristic of the 3G Taco.
  11. Aug 10, 2021 at 12:20 PM
    #51
    JAL
    Mississippi
    Tech708cc,
    I only ask about the OV tune as it wasn’t clear to me and it’s the only tune I’m aware of that all others use as their base to develop from.
    It’s nice to have options.
  12. Aug 10, 2021 at 12:21 PM
    #52
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Both my buddies and my tacoma operate at roughly the same speeds and rpm on the back roads here. His truck will start to shudder or buck lightly if the rpm get down to around 1200. With my truck nothing, plus it has noticeably more torque that far down. Both have the same tsb latest tune. I believe some truck don't experience this while others do.
  13. Aug 10, 2021 at 12:30 PM
    #53
    JAL
    Mississippi
    My experience here after reading many post on this particular issue/characteristic is not all trucks are equal.
    But I do know what mine does and this is my biggest grievance with it.
    By the way I’m KDMAX 6 tuned and it has done amazing things to shifting, normal cruise, and hill climbing overall drivability. If this misfiring was taken care of it would be perfect!
  14. Aug 10, 2021 at 12:48 PM
    #54
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    It would be nice and very helpful to understand valve timing/timing , etc tuning.
    Personally, I'd like to optimize timing and make more stable. See alot of retardation in mid load range
  15. Aug 10, 2021 at 12:56 PM
    #55
    gudujarlson
    Minnesota
    At the risk of stating the obvious, any gasoline internal combustion engine (at least all that I know of) will misbehave if you give them too much throttle at too low a rpm. The electronically controlled engines of today deal with it a lot better than the carbureted engines of the past, but they still have limitations.
  16. Aug 10, 2021 at 12:57 PM
    #56
    Tech708CC
    2020 trd off-road
    I do appreciate the advice and will try to clear up confusions. There is just a lot of data I wanted to get out and making it all make sense was a bit difficult.
    I suppose I should say that my Thesis is "The gains to be had from Tuning"
    The mechanical side of things has pretty much been
    1. Muffler then moved to catback (catback made no more power than just a weld in aftermarker muffler)
    2. HPS intake tube with K&N, trd air flow accelerator, and remove charcoal filter
    3. Y pipe of my own making (This was done in between my 2nd and 3rd drag strip visits and proved to help with the MPH in 1/8 and 1/4 mile tests)
    Now the gains to be found from tuning is what I was researching.
    I started with a nGauge(tuning interface) from D3 Performance which had their tunes preinstalled.
    I found the Wide Open Throttle performance of their tunes was good but the trans stuff needed more work so I began to write my own tunes using their (D3 Performance) Software.
    Their tune was locked and I was not able to see any of it so when I began to tune I had to start from scratch so this tune is all my own doing
    shotgunbilly420 likes this.
  17. Aug 10, 2021 at 1:07 PM
    #57
    Tech708CC
    2020 trd off-road
    The intake base angle effects how much timing you can give it as this varies the cylinder filling. More base angle the less aggressive you can get with timing. I am sure you have been watch kclv and the knock feedback.
    In my latest tune my kclv varies 21-24 depending on temp and driving style. The worst Knock feedback is seen in that 1400-1800 range when transitioning to a higher load and trying to maintain a higher gear. I have seen -5 to -6 but only for a brief moment. Then also during wot after a shift when it goes back to say 4.5k - 5k rpms I might see a -5 spike for a brief moment. I have been beating on my truck for a while like this and have seen no issues and of course never heard any audible knock. You can watch when your kclv goes up to say 24 or so and its really getting aggressive with the timing that is when it advances a bit too much picks up knock and settles back down to a kclv of 21 or so and the cycle starts again.
    What kind of knock feed back are you getting and at what kclv are you getting it?
  18. Aug 10, 2021 at 1:10 PM
    #58
    Tech708CC
    2020 trd off-road
    I would love to see a sub 2.0 60ft but with this dog legged rear end its a bit tough. I need to go reread that post on how to make the diff lock operate in 2wd.
  19. Aug 10, 2021 at 1:21 PM
    #59
    Vlady
    Issy, WA
    I did some slight changes and I sit 19.5-22 on 87 but if I stay too long in 1500-1800 range (65 mph drive for 20-40 miles), I would go to 17-18 and the cycle repeats over.. Feedback floats between 3.5-5.0
    Going at 3500 rpms in 4th over a pass, I see 15°
    I see same -5, -6 spikes and see them when there is a change to the valve timing.
  20. Aug 10, 2021 at 1:29 PM
    #60
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'm sure you're aware OP, but any tuning details (I mean actual values going into tables) you share on here will most likely be immediately monetized by others who are already tuning trucks all over the continent. Something to consider if you think your time and knowledge are valuable. I mean, those guys lock their tunes for a reason. Why shouldn't you get paid too?
    Just sayin.
