Performance tune
Discussion in 'Performance and Tuning' started by Tarpon24, Jun 23, 2012.
  1. Jun 26, 2012 at 4:08 PM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    There is another thread for that whipper. Not going to clutter his thread with that. Besides. What experience do you have with one on this truck?
  2. Jun 26, 2012 at 4:10 PM
    #42
    whippersnapper02
    whippersnapper02 Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    I had a TRD. It made a lot of noise and I felt a little bump at top end but that's it. It made more noise than it was worth so I sold it.
  3. Jun 26, 2012 at 4:41 PM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    In that case, I will rephrase my comment. The TRD style, and yes it does make noise, is bounds better than a K&N style. Due mainly to the fact of engine bay heat saturation of the K&N style since they are not in an enclosed container in the engine bay. The trd style is, and draws its air from the fender well.
    It is less restrictive than factory in the simple fact, that its design is basically a smooth straight line. Compared to the factory one which has many turns and ripples throughout.
    They won't hurt your MPG, and gains will be limited in MPG, when adding a good one. Still depends on how heavy the foot is as well as other factors.
    The three I mentioned will give you a gain in HP and torque, proven by dynos, but nothing that will make a significant butt dyno feel, if you drive like Miss Daisy.
    Increasing your tire pressure by 5 psi, will help, if yours is low. However, that will require some testing as well.
  4. Jun 27, 2012 at 9:25 AM
    #44
    Tarpon24
    Tarpon24 [OP] Well-Known Member
    Frankie
    Fl
    Trd
    Leveling kit, 20 in rims, flowmaster true duals, bullying watch dog,
    I did buy the afe stage 2 with the dry filter looked like everyone liked it the best. An I increased my tire psi from 32 to 40 psi 2 days ago and I think that was the problem brought my mpg from 11 to 15. I just checked it when I filled up last night.
  5. Jun 27, 2012 at 9:42 AM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Good deal. Lots of people easily overlook the tire pressure. Mainly because they just forget about it. I have done it as well. Your rolling resistance increases significantly as your tires get wider. Even more compounded as the tire pressure goes lower.
    I believe that it is an average of 1-2 MPG loss, per 5 psi decrease in pressure. Of course, that will also vary on tire width. Wider obviously having a greater affect than narrower, as well as tread patterns.
    www.southwestresearch.com. They have data analysis for different size tires and pressures, if you feel inclined to look it up.
    I am glad you found some MPG and performance.
    Also, have you been accounting for the difference in you tire size, and it throwing your mileage off?
  6. Jun 27, 2012 at 3:14 PM
    #46
    Tarpon24
    Frankie
    Fl
    Trd
    Yea thank a bunch. I'm actually around 17 now pretty happy. And I didn't need the " Prius" mod.
  7. Jun 27, 2012 at 3:18 PM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Glad to have helped. :thumbsup:
