Perishing Gas Mileage?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Jul 30, 2015.
  1. Jul 30, 2015 at 9:40 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I have a 2002 Taco Double Cab with the 2.7L in it. My gas mileage at the moment is at 14 MPG. When I first bought the truck a year ago I was hitting 17-18 in the city. Now does anyone has any clue why my gas mileage is taking a serious beating? It's been slowly declining over the last few months.
  2. Jul 30, 2015 at 9:43 PM
    tacotuesday4x4
    tacotuesday4x4 Well-Known Member
    2011 tacoma TRD off road
    Bilstien 5110, 1" lift blocks, kenda klever m/t 32"
    I notice my mileage start to dive around the time i need a service mine is a 2nd gen though
  3. Jul 30, 2015 at 10:09 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'd tune it up to start with (air filter, plugs, pcv, clean MAF, oil/filter change, etc).
    Then check valve clearances.
    Do a compression check.
    Check the resistance of as many sensors as you can.
  4. Jul 31, 2015 at 7:02 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    first off, stop posting the same thread every 3-4 minutes and just wait for someone to help, thank you
    now to the question:
    can be lots of things but is the truck still running smoothly? any signs of power loss or hesitation?
    when was the last time you replaced the air filter and changed the plugs?
    a compression test is a good idea and the plugs need to be checked anyway to see if they are worn or wet with gas.
    also check the engine oil level and smell it, is it higher then it should be or smell like gas? if so your injectors might be leaking
  5. Jul 31, 2015 at 1:56 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Possible O2 sensor. My mileage started decreasing before I got a CEL for a bad O2 sensor
  6. Jul 31, 2015 at 4:11 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Could likely be the O2 sensor. Changed mine for the hell of it and gained about 1.5 mpg.
    The most common bad MPG reasons besides mechanical:
    1.) Crap Gas, use High Tier Stations (Ethanol does not do your MPG's any good either)
    2.) Lead Foot
    3.) AC on constantly
    4.) City driving
  7. Jul 31, 2015 at 9:39 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    The site did that, not me. But thanks :thumbsup:
