Permanent Rausch Creek thread
Discussion in 'North East' started by armyofsquirrels, Feb 27, 2016.
  1. Dec 8, 2016 at 1:50 PM
    #2001
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    I have a rear locker and still need pulled sometimes. Haha. However when I do get stuck it's typically REALLY stuck.
    Nimble9 and Blackout14 like this.
  2. Dec 8, 2016 at 2:15 PM
    #2002
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Not wheeling at Rausch??
  3. Dec 8, 2016 at 2:20 PM
    #2003
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    You're right Garrett. The link refers to an aftermarket AAL added to a factory leaf pack.
    "An add a leaf (does not) magically increase droop of the factory leaf pack".
    I agree with this completely. This was my setup in my initial foray into suspension upgrades: A factory leaf pack plus a 3 leaf AAL designed for the factory leaf pack. I improved my spring rate and my load carrying capability, but not my droop.
    The AAL that I am referring to on my current setup is the OME DAKAR 29XL AAL, which matches up to the OME Full Leaf pack that I have. This AAL will not work with OEM leaf packs. My setup increases the mentioned (in your link) spring rate. The OME AAL helps maintain the already improved droop of the OME leaf pack over a greater payload range. The droop and progressive compliance over rough terrain is much improved over stock.
    How do I know that the droop is improved with my Dakar leaf combo? Because I needed the longer B110's and the shocks are already fully extended.
    How do I know that doing a shackle flip will increase my droop further? Because I will need even longer shocks, or add limit straps because my B110's are already fully maxed out with my non-shackle flipped current Dakar+ 29XL combo.
    But my question to all is: Why add limit straps after adding a shackle flip? Wouldn't that be the same as NOT adding a shackle flip and NOT adding limit straps? Is there additional benefit to the shackle flip that I'm not understanding?
    BTW, the Dakar 29XL AAL is actually the same exact leaf of the second (from the top) spring of the OME Dakar Leaf pack. In terms of length, width, bend radius and spring rate.
  4. Dec 8, 2016 at 2:25 PM
    #2004
    Subway4X4
    Lloyd
    NY/NJ
    Vultures already circling. LOL.
    My HS 3 leaf AAL's, rear 5100's and front 884X's already claimed by @diabetik81
    My current Dakar AAL is staying attached to my Dakar leaf pack for 5 or 10 years.
    If I do my shackle flip and blow out my B110's - then they're FREE!
    Shackle flip is still a big question mark. Unless I can find relatively inexpensive longer shocks than the B110's.
    fatfurious2 likes this.
  5. Dec 8, 2016 at 2:37 PM
    #2005
    Subway4X4
    Lloyd
    NY/NJ
    The welding is never finished.
    You will need to kiss @stairgod 's ass indefinitely.
  6. Dec 8, 2016 at 2:38 PM
    #2006
    Subway4X4
    Lloyd
    NY/NJ
    THIS IS WHAT I WANT DO.
    Blackout14 and fatfurious2 like this.
  7. Dec 8, 2016 at 2:38 PM
    #2007
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    What RTT group buy? I just bought a bed cage
    Blackout14 likes this.
  8. Dec 8, 2016 at 2:39 PM
    #2008
    fatfurious2
    David
    Ashburn, VA
    Gotta get big boy suspension
  9. Dec 8, 2016 at 2:39 PM
    #2009
    Subway4X4
    Lloyd
    NY/NJ
    You missed the RTT GB?
    Everyone got in on this GB.
    :boink:
  10. Dec 8, 2016 at 2:40 PM
    #2010
    Subway4X4
    Lloyd
    NY/NJ
    Anther shock snob!
  11. Dec 8, 2016 at 2:42 PM
    #2011
    Manual man74
    Manual man74 Well-Known Member
    Garrett
    Goshen NY
    2015 trd off road dcsb mt
    Just getting started
    I obviously don't have dakars. so I am researching and trying to help. but on the second thread that I linked it looks like with your leafs you get 9" of travel. B110 have 11" of travel. so Im confused as much as you are as to how you are maxing out your droop? I should also let you know I don't know shit about suspension, just trying to help.
    How would installing the 29xl increase your travel numbers on your ome leafs? I would like to know for my own knowledge.
    Note I'm not trying to come across as a dick. don't read it as such.
  12. Dec 8, 2016 at 2:43 PM
    #2012
    fatfurious2
    David
    Ashburn, VA
    I wasnt in the market. Now that i purchased the cage, I am. Also, I heard CVT gives 15% off for TW members. But yet to confirm that.
    Did you get one @Subway4X4 ?
  13. Dec 8, 2016 at 2:43 PM
    #2013
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I just love the way the morning sun shimmers off of his perfectly quaffed Mohawk?
    stairgod and Subway4X4[QUOTED] like this.
  14. Dec 8, 2016 at 2:46 PM
    #2014
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    @Box Rocket does 10% off Tepui for TW folks. You have options :thumbsup:
  15. Dec 8, 2016 at 2:47 PM
    #2015
    fatfurious2
    David
    Ashburn, VA
    Im going to wait for a bit. Probably not going to be doing much winter camping. And I need to wait for my cage to ship/be delivered
  16. Dec 8, 2016 at 3:05 PM
    #2016
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I've never tried not wheeling there, besides making deliveries or pick ups haha
  17. Dec 8, 2016 at 3:11 PM
    #2017
    Subway4X4
    Lloyd
    NY/NJ
    Appreciate the help Garrett.
    I don't understand those numbers as well.
    Bilsteins specs are:
    • Extended Length: 27.28"
    • Collapsed Length: 16.34"
    • That is 10.94" of travel, commonly refereed to as an 11" stroke shock.
    I measured my shocks. Here it is at full droop. 27"
    So my conclusion is that I'm getting 11" of travel with the Dakars+ AAL.
    I didn't think that the 29XL increases the travel numbers of the Dakar leafs. I was thinking that the OME AAL helps maintain the already improved droop of the OME leaf pack over a greater payload range (because of the increased spring rate.)
    But, with the measured travel (above pic) with these AAL's, then a natural conclusion would be that somehow, the Dakar AAL's improved the travel numbers.
    Not taking it that way at all.
    Me too.
    Thanks again
  18. Dec 8, 2016 at 4:02 PM
    #2018
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    What RTT?
  19. Dec 8, 2016 at 4:05 PM
    #2019
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    I think its 10% same as military discount unless he upped it.
    fatfurious2[QUOTED] likes this.
  20. Dec 8, 2016 at 4:21 PM
    #2020
    Subway4X4
    Lloyd
    NY/NJ
    There you go. Back on track...
