Permanent Rausch Creek thread
Discussion in 'North East' started by armyofsquirrels, Feb 27, 2016.
  1. Mar 11, 2016 at 3:58 AM
    #221
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Run the lower watt ones and you will be fine. I had them for 3 months no problems. No real risk at all
  2. Mar 11, 2016 at 4:04 AM
    #222
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    I have done the 886 mod,just out of curiosity.(on my tundra) At the shop i work at at night,a couple a years ago we aquired an old parts suppliers old inventory (went out of business).So i did this mod because it didnt cost me anything,Much brighter,They do get hot though but i don't leave my truck in reverse for long periods of time.
  3. Mar 11, 2016 at 4:33 AM
    #223
    armyofsquirrels
    armyofsquirrels [OP] Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    Good to know there was one guy who said he ran the 35w and melted his connector
  4. Mar 11, 2016 at 5:08 AM
    #224
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    For future reference, I'll try to get some photos when we do Extinguisher training next time, so you guys can see it, we've cleaned up most of the Dry Chem powder down on the grounds. I'd also recommend staying away from PW cans (pressurized water extinguishers) I'm not sure about tacomas, but if you come across a car fire and go to use it, chances are there is magnesium in the car (typically older though I've seen it in newer SUVs) and well. Lets just say you will need a new pair of underwear.
    HomerTaco likes this.
  5. Mar 11, 2016 at 7:53 AM
    #225
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Halon is the way to go, right Liz?
  6. Mar 11, 2016 at 7:57 AM
    #226
    mitchellak
    mitchellak Well-Known Member
    Aaron
    Severn, MD
    TRD Tacoma
    Toytec ultimate lift LR UCA DAKARS ICON RR BEEFED Sliders Airflow Snorkel Pelfreybilt hybrid front Pelfreybilt highclearance rear
  7. Mar 11, 2016 at 7:58 AM
    #227
    cynicalrider
    cynicalrider #NFG
    Jersey
  8. Mar 11, 2016 at 8:56 AM
    #228
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Correct, Basiclly you want anything rated for an A, B or C class fire. Since that is what makes up most of a truck. D and K are combustible metals (magnesium) and cooking oils or fats... which... I don't think any of you keep in your vehicles.
    or you can go the NASCAR route and get a Purple K one... (comical if it goes off accidentally in the cab of a truck..)
    if you guys like Wiki you can read more about them here, or if you guys want to I can get the class we teach and make a thing up for you guys to read, if you want to learn more about them :)
    https://en.wikipedia.org/wiki/Fire_extinguisher
  9. Mar 11, 2016 at 9:10 AM
    #229
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    lots of magnesium in the suspension components of newer cars and lighter duty SUVs. usually control arms and spindles. not sure of the Mg% in the alloy, but they are marketed as magnesium, so it must be pretty significant.
    pretty sure the raptor runs Mg lower arms. that would be a pretty sight n fire!
  10. Mar 11, 2016 at 9:19 AM
    #230
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    If I remember my chemistry correctly Magnesium is difficult to ignite except in a powdered form... It would have to be really hot to fire up those LCA's...
  11. Mar 11, 2016 at 9:43 AM
    #231
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you can ignite small strips pieces with a butane lighter, and slightly thicker pieces with a map gas torch. An LCA like that probably takes and oxy torch.
    Are you thinking thermite by any chance? that's an iron oxide/aluminum powder mix, where you typically light a piece of magnesium with a lighter, which then burns hot enough to ignite the thermite.
  12. Mar 11, 2016 at 9:45 AM
    #232
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    they were suppose to do away with the mag, due to all the injuries from car fires... clearly that didn't happen
    Those LCA's will cause a nice pop should the engine compartment be fully engulfed in flames. Hell even the passenger compartment will cause them to pop once the water is applied.
  13. Mar 11, 2016 at 9:47 AM
    #233
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    As for the pop:
    https://youtu.be/IxRJIOJqP3I
    https://youtu.be/zLoF99LYdts
    I've had a few "pop" on me, last one I was on actually, the pendot camera caught me and the girl who was on the tip of the line, you can see me pull her back in one photo and the next the white flare up....
  14. Mar 11, 2016 at 9:49 AM
    #234
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  15. Mar 11, 2016 at 10:14 AM
    #235
    cynicalrider
    cynicalrider #NFG
    Jersey
    A hummer magnesium runflat is enough to light the sky with a giant flood of light when put in the fire at Rausch. I wasn't even at camp and I could see the sky light up.
  16. Mar 11, 2016 at 10:51 AM
    #236
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    My friend lit a small strip of magnesium because he said it looked cool when we were younger. That was the brightest thing I think I've ever seen minus the sun or a welding torch.
    I can't imagine anything bigger.
  17. Mar 11, 2016 at 10:52 AM
    #237
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    No idea, I've not been as attentive as I use to be, just starting to get back into the fire side of things, spent the last 6 years on 3 different ambulances... New job brought me back into the fire service so I'd have to dig into it more to answer that question, I do know they use to use a lot of it in dash boards, I believe it was use in the fire wall.
  18. Mar 11, 2016 at 10:53 AM
    #238
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Those dumbasses in the first video not wearing SCBA are just down right stupid. NEVER EVER EVER EVER fight a car fire without being fully geared up.
    TinyTech626[QUOTED] likes this.
  19. Mar 11, 2016 at 12:46 PM
    #239
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I think Rausch Creeks domain name expired or something. Can anyone get on their site?
  20. Mar 11, 2016 at 1:17 PM
    #240
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
