Permanent Rausch Creek thread
Discussion in 'North East' started by armyofsquirrels, Feb 27, 2016.
  1. Mar 27, 2017 at 8:27 AM
    #5441
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Do the re route!
  2. Mar 27, 2017 at 8:28 AM
    #5442
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    The one in the photo I just slipped off a rock onto my axle, no biggie. I got stuck worse in North Jersey and also going up 1c I basically just dragged my truck up
  3. Mar 27, 2017 at 8:30 AM
    #5443
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I like my line choices :thumbsup: .....usually.....
    I must be doing something right I guess.
  4. Mar 27, 2017 at 8:39 AM
    #5444
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    Thanks that was supposed to say,w/reroute.
    Blackout14 likes this.
  5. Mar 27, 2017 at 8:40 AM
    #5445
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    I don't have that luxury... days off are a weeks notice
  6. Mar 27, 2017 at 8:40 AM
    #5446
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    :drool: I don't think it would've looked like that if I took that bump at speed lol
    stairgod[QUOTED] and steele-taco like this.
  7. Mar 27, 2017 at 8:42 AM
    #5447
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Except sick days
  8. Mar 27, 2017 at 8:42 AM
    #5448
    steele-taco
    james
    Jersey shore
    Looked good coming in and coming out.
    Blackout14 and stairgod like this.
  9. Mar 27, 2017 at 8:50 AM
    #5449
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Lunch time!
    HolyHandGrenade and stairgod like this.
  10. Mar 27, 2017 at 8:52 AM
    #5450
    Subway4X4
    Lloyd
    NY/NJ
    I'm not the only dude that had to climb out of the door window opening cuz I was caught between a rock and a hard place:
    Greg @El Dahs slightly stuck:
    El Dahs and stairgod like this.
  11. Mar 27, 2017 at 8:55 AM
    #5451
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Actually looked at this vid for a while. Slow no. Need to make some changes. Valving mostly.
    steele-taco[QUOTED] likes this.
  12. Mar 27, 2017 at 9:03 AM
    #5452
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I don't know what a day off is anymore. Haven't had one in a couple years.
  13. Mar 27, 2017 at 9:10 AM
    #5453
    Subway4X4
    Lloyd
    NY/NJ
    @jowybyo and @Lindsay @ Mobtown Offroad need to start picking up the slack
  14. Mar 27, 2017 at 9:12 AM
    #5454
    El Dahs
    El Dahs I am DTF. Down To 'Froad
    The Real Slim Shadle
    2000 Ford Ranger
    Dents and scratches
    I had to get out and inspect the damage. If you look close enough the passenger rear fender is sticking out a little further than usual.
    stairgod likes this.
  15. Mar 27, 2017 at 9:13 AM
    #5455
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Choose your point of failure and work backwards. I chose ball joints as they are the least costly to replace and I have all the tools necessary. Being that you have already gusseted your spindles, the force of hitting the bump stops at speed will go to the LBJ and the LCA joints. You can reinforce factory LCA joints by welding an extra strap around the bushing barrel. Closing down the valving on the compression stroke will put the force into the joints earlier than when the hitting the bumps. Same energy spread over a longer time equals less damage.
  16. Mar 27, 2017 at 9:13 AM
    #5456
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    We don't have those. Still have to come into work sick to see the doctor
  17. Mar 27, 2017 at 9:18 AM
    #5457
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Exactly my train of thought. A slight increase on compression valving should absorb more of the energy sooner, keeping the hit on the bumps a little lighter.
    steele-taco and Blackout14 like this.
  18. Mar 27, 2017 at 9:20 AM
    #5458
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Yep
  19. Mar 27, 2017 at 9:23 AM
    #5459
    cynicalrider
    cynicalrider #NFG
    Jersey
    This stream crossing has changed quite a bit since I've run that trail. We were also running it the other way and trying to go up that big hill you guys came down. Needless to say we werent successful.
    kyuss88, uurx and Blackout14 like this.
  20. Mar 27, 2017 at 9:23 AM
    #5460
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    The ass end seemed alot more composed than the front. Was thinking I needed a bit more rebound dampening on the front for a while. Guess I need to dampening both sides more. The valving was not changed from what DSM specs, despite the heavoer springs. I had thought that dampening should have been increased from the get go due to the extra weight on the front end.
