Permanent Rausch Creek thread
Discussion in 'North East' started by armyofsquirrels, Feb 27, 2016.
  1. May 10, 2017 at 6:43 AM
    #6741
    cynicalrider
    cynicalrider #NFG
    Jersey
    Our IFS skids are a little more complicated than our t-case or transmission skid, so don't let @The Hunter think it's going to be a walk in the park when he has no fucking clue how ours are designed. Still not terribly difficult, but it needs several almost 90* bends and should take advantage of the front crossmember like the stock skid does, so needs tube extensions or something similar to mount to that.
    Skid row does a good job with theirs and is pretty cheap, I got mine for like $260 through Quadratech. You can see the supports and bends in these pics:
    Relentless takes it a step further by adding a much needed gusset to the supports as well. They are pretty comparable at $289 for 3/16, and honestly if I were to buy a new one it would probably be a relentless 1/4".
    Mobtown Offroad and MY50cal like this.
  2. May 10, 2017 at 7:16 AM
    #6742
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I think you are over thinking it. It just needs some heat to prevent stresses from building up.
    From artec industries:
    "Place about 3/4" long stitch welds between the axle tube and the truss pieces taking care to not let axle tube heat up too much in one area. For best results, weld one stitch and move to a completely different part of the
    axle for the next weld. This will allow the first area to cool. Take your time. If welded too hot, the axle may warp upon cooling. A welding blanket may help slow the cooling and reduce the chance of warpage.
    STEP 7. Before welds cool too much, replace pieces 0 and 1 back on assembly and tack weld them to assembly.
    Once all welds have sufficiently cooled, proceed to weld exterior of truss in a similar manner as in step 6. Re-
    member to take your time and spread out your welds. It is not necessary for every seam to be completely welded.
    STEP 8. To weld truss to cast section with best results, preheat casting evenly around where truss contacts to ap-
    proximately 400 degrees. DO NOT HEAT UNTIL GLOWING RED AS THIS MAY DAMAGE THE CASTING.
    Once preheated, weld truss to casting before it cools. For best results, use a needle scaler or peening hammer to
    relieve the weld directly after welding. Post heat the area to approximately the same temp you used to preheat.
    Wrap axle in a welding blanket to slow the cooling process, the cooling should be slow (18-24hrs.) and uniform.
    (The idea behind this method is to relieve the stresses in the materials prior to welding, and ensure that the plate
    steel does not cool quicker than the cast resulting in stress cracks.)"
  3. May 10, 2017 at 7:46 AM
    #6743
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    It's not great Jeep, it's the pissed off wife. If it were his truck I'd go for it :)
  4. May 10, 2017 at 8:04 AM
    #6744
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    From what I have read, if using MIG to do it, it is best to use stainless steel wire as it has the closest properties to cast. I definitely agree with pre and post heating, especially the cast section, as it is much thicker and cast draws heat away from the weld area very quickly.
  5. May 10, 2017 at 8:07 AM
    #6745
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Pre heat, weld, peen, post heat, wrap in blanket...Seems do able
    Mobtown Offroad and stairgod like this.
  6. May 10, 2017 at 8:08 AM
    #6746
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I'll look into the wire :thumbsup:
  7. May 10, 2017 at 10:06 AM
    #6747
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Definitely doable. Hardest part for me is the heating. My oxy acetylene outfit is buried in my one shed, out of oxygen, and both tanks are way out of test...lol
    Blackout14 likes this.
  8. May 10, 2017 at 10:08 AM
    #6748
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    jim's got a propane torpedo I think that'll do it
    The Hunter likes this.
  9. May 10, 2017 at 10:16 AM
    #6749
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    MAPP gas would do fine I think...
  10. May 10, 2017 at 10:22 AM
    #6750
    cynicalrider
    cynicalrider #NFG
    Jersey
    You mean you can't put the entire axle in the grill this time @Sub-Zero? :p
    The Hunter and Blackout14 like this.
  11. May 10, 2017 at 10:27 AM
    #6751
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Nope. You can sweat copper with it, but just not enough heat or volume of heat for an axle housing.
  12. May 10, 2017 at 10:36 AM
    #6752
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    I'm ready to come hit up rausch creek
    stairgod likes this.
  13. May 10, 2017 at 10:38 AM
    #6753
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I am local to it. Let me know when you want to come up.
    Toyota Takeover is end of July.
    Acerwin[QUOTED] likes this.
  14. May 10, 2017 at 10:39 AM
    #6754
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Saw y'all are going to windrock. Get ready to dish some money out there. I paid around $220 for a weekend trip lol. Great park tho and ready to go back.
    M192 likes this.
  15. May 10, 2017 at 10:39 AM
    #6755
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Definitely might come
    stairgod[QUOTED] likes this.
  16. May 10, 2017 at 10:57 AM
    #6756
    Arcticelf
    Gladiator
    Hopefully there's a June trip too. Although I've got some work to do before going out again.
  17. May 10, 2017 at 11:02 AM
    #6757
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Bumper project?
  18. May 10, 2017 at 11:04 AM
    #6758
    Manual man74
    Manual man74 Well-Known Member
    Garrett
    Goshen NY
    2015 trd off road dcsb mt
    Just getting started
    I have acetylene.
  19. May 10, 2017 at 11:05 AM
    #6759
    Arcticelf
    Gladiator
    Yup. Need to get reinforcement onto my skid, and finish the bumper.
  20. May 10, 2017 at 12:57 PM
    #6760
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    That could work better
    Blackout14 and Arcticelf like this.
