Permanent Rausch Creek thread
Discussion in 'North East' started by armyofsquirrels, Feb 27, 2016.
  1. Nov 30, 2017 at 2:09 PM
    #8701
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I believe that spring rate (590 lbs is the OME 883, 884, 885, 887 and 888) means that it takes 590 lbs of force to compress the spring 1".
    bski22 and The Hunter like this.
  2. Nov 30, 2017 at 2:11 PM
    #8702
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    I should. But my TCs don’t cause my OME setup to over extend. But they do clunk after full droop is achieved.
  3. Nov 30, 2017 at 2:14 PM
    #8703
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    So all those OME have the same spring rate? Why the different variations? Would spring rate be affected by heavier weight on the truck, ie bumper winch?
    Or is it that they are the same spring weight when the added weight is there on the heavier duty coils?
    When I see 620lb springs and 700lb springs and 500lb springs (or whatever OEM is) what does that mean?
  4. Nov 30, 2017 at 2:14 PM
    #8704
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Have some faith in 5100s and a bumper/winch... upgrade to the eibach coil and itll be fine.
  5. Nov 30, 2017 at 2:14 PM
    #8705
    planters15
    planters15 Well-Known Member
    Q (irfan)
    Pa - Spring City
    2010 Double Cab SR5 6spd
    Stuff to make go more off road
    FIFY.
    He knows I'm just busting his balls for the most part.
    The Hunter and Blackout14 like this.
  6. Nov 30, 2017 at 2:16 PM
    #8706
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    The OME coils are either longer or a heavier spring rate going up from lowest to highest. It should be listed on ARBs website
    Redmann[QUOTED] likes this.
  7. Nov 30, 2017 at 2:16 PM
    #8707
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    custom car grill, KORE sliders, light bar, KORE bed bars w/ tire and high lift mount. MOBTOWN front IFS skid.
    You ought to specify from which end....
    bski22 and Subway4X4[QUOTED] like this.
  8. Nov 30, 2017 at 2:17 PM
    #8708
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    :brianr: reported.
    Redmann likes this.
  9. Nov 30, 2017 at 2:18 PM
    #8709
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Ohhh look you are both quoted in the same post ;)
    So @Subway4X4 I spotted an OME CO setup for sale on craigslist. Nitro 90000 shocks and 886 springs for $500 brand new. Recommended?
    @The Hunter the Eibach springs will work with the 5100s?
  10. Nov 30, 2017 at 2:18 PM
    #8710
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The variations in OME coils is the overall length, which is why different coils are recommended for different can variations.
    For argument sake, let's say the front of the Tacoma weighs 1000 lbs, and comes oem with a 500 lb coil. This rate of cool pairs nicely with the 1000 lb, and can handle that weight. Once you add skids, bumper and winch you bump that bumper up to 1,300 lbs. With a 500 lb coil, it'll be a lot easier to compress now, so you need to increase the spring rate to compensate for the added weight.
    In laymans terms, if you add more weight up front, you need to get a higher rate coil, and a shock to go with it.
    Redmann[QUOTED] and Blackout14 like this.
  11. Nov 30, 2017 at 2:19 PM
    #8711
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Would recommend. That's what I'm installing tomorrow.
  12. Nov 30, 2017 at 2:19 PM
    #8712
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    I can learns you good stuffs.
  13. Nov 30, 2017 at 2:20 PM
    #8713
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Thanks guys. I'm doing this all from my phone. Just passing time at work haha
    Blackout14 likes this.
  14. Nov 30, 2017 at 2:21 PM
    #8714
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Good thing I have a grinder
  15. Nov 30, 2017 at 2:22 PM
    #8715
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    LMFAO
    Redmann and Blackout14 like this.
  16. Nov 30, 2017 at 2:22 PM
    #8716
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    OEM - Original Equipment Manufacturer AKA factory Coils.
    Here are the spring rates of coils that will FIT* your 5100's:
    Eibach 112-620 coils 620lb spring rate 381mm in length
    Eibach 52-1600 lift coils 610 lbs spring rate 391 mm in length
    OME 883 coils 590 lbs spring rate 375 mm in length
    OME 884 coils 590 lbs spring rate 390 mm in length
    OME 885 Coils 590 lbs spring rate 395 mm in length
    OME 886 coils 660 lb spring rate 402 mm in length
    OME 887 coils 590 spring rate 400 mm in length
    * Note that all theses coils will physically FIT the 5100's. The 5100's may not be valved properly for the heavier 660 lb 886's
    I think your dilemma is: Should I get the heavier 886 OME Coils to work with my 5100's, winch and bumper? This is where you need to start looking at all the input you are getting now from everyone and make the decision.
    If you do decide to go this route, know that if you go towards the larger body B6112's in the future, then you still need to get a different set of heaver coils for that shock.
    From a convo that I had with Marie at Headstrong long ago: Now on a stock double cab 4x4 the OME 884X coils will provide approx. 2" of lift but since you are running the additional weight up front this can bring the lift down some. How much is hard to say. You could go with the OME 885X coils which provide approx. 2.5" of lift on a stock double cab 4x4 and see if the extra up front weight brings the coil down toward the 2" mark.
  17. Nov 30, 2017 at 2:22 PM
    #8717
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    I usually only unwelcomingly welding stuff to peoples trucks after they bear spray me.
  18. Nov 30, 2017 at 2:23 PM
    #8718
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    All over the DS !
  19. Nov 30, 2017 at 2:24 PM
    #8719
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I know what OEM is silly boy. I meant whatever pound a OEM spring is. :bananadead:
    Thaks for that info
  20. Nov 30, 2017 at 2:25 PM
    #8720
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    I was recommended 5100's and OME 885's for my attempt at a 2.5" lift. Is this no bueno?
