Permanent Rausch Creek thread
Discussion in 'North East' started by armyofsquirrels, Feb 27, 2016.
  1. Nov 30, 2017 at 2:26 PM
    #8721
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    OEM is 500 I believe. The OME are 590
    It's fine. That's what I've ran on two separate trucks. It's an awesome budget lift.
    Blackout14 likes this.
  2. Nov 30, 2017 at 2:30 PM
    #8722
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I believe @EatSleepTacos is right with the 500. But wtf do I know. I'm asking questions not answering them hah
    EatSleepTacos and Blackout14 like this.
  3. Nov 30, 2017 at 2:31 PM
    #8723
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    One of the most common setups in TW.
    EatSleepTacos, Blackout14 and Redmann like this.
  4. Nov 30, 2017 at 2:41 PM
    #8724
    Subway4X4
    Lloyd
    NY/NJ
    I can't make the recommendation coz I've never run this setup. But I think it's a common setup.
    But @HolyHandGrenade may have. I know for sure @Sub-Zero has, and maybe still is.
  5. Nov 30, 2017 at 2:46 PM
    #8725
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Simple version: when any wheel is off the ground something has to stop the suspension down travel. On an OEM suspension that's the shock running out of travel. This is fine, because it keeps everything else inside comfortable working parameters; but it means that a) you don't get all the possible down travel out of the suspension and b) if you rapidly lift the truck off the ground (think jumps or similar) the spring pushes that shock into it's stop with a fair amount of force.
    Because we all want travel for wheeling the solution to a) is a longer travel shock, backed by a bigger spring to provide lift and support our heavy armor/bumpers. Now the limiting factor is either the articulation range of the joints (ball or uni) or the UCA hitting the coils. With the lifted ride height alignment is an issue too. So we go to an after market control arm, which changes the location of the joint (relative to the frame) and allows more articulation. For wheeling around here (no jumping) using the shock as a limiting factor is probably fine. Crashing the UCA into the spring isn't great, but ok. Using a Ball Joint to limit articulation will kill them, as they are not meant for this, and neither are the protective boots that keep the grease in.
    My Opinion: when we mess with the stock design we're re-opening the box of engineering trade offs that Toyota made at the factory. There is a good reason they made the choices they did, however with some knowledge of how it all fits together you can get better performance and acceptable tradeoffs. My system trades maintenance and noise for travel, YMMV.
    I'd suggest the Mdi Travel BS thread as a good place to start. https://www.tacomaworld.com/threads/mtbs-2-0.410188/
    Dogg23, steele-taco, bski22 and 3 others like this.
  6. Nov 30, 2017 at 2:46 PM
    #8726
    planters15
    planters15 Well-Known Member
    Q (irfan)
    Pa - Spring City
    2010 Double Cab SR5 6spd
    Stuff to make go more off road
    Only if you plan on getting steel bumper or winch.
  7. Nov 30, 2017 at 2:46 PM
    #8727
    Subway4X4
    Lloyd
    NY/NJ
    He's stock bumper/ no winch right now Q.
    But he's now got the bug...
  8. Nov 30, 2017 at 2:49 PM
    #8728
    planters15
    Q (irfan)
    Pa - Spring City
    Then yes that's fine. That's what I started with. If he plans on a winch or steel bumper then 886 springs.
    Blackout14 and Subway4X4[QUOTED] like this.
  9. Nov 30, 2017 at 2:50 PM
    #8729
    Arcticelf
    Gladiator
    Bumper/winch first - saggy ride
    Springs/shocks first - rough ride
    Ideally: buy everything as it goes on sale and do a single mod day.
  10. Nov 30, 2017 at 2:53 PM
    #8730
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Arcticelf and Blackout14 like this.
  11. Nov 30, 2017 at 3:00 PM
    #8731
    Arcticelf
    Gladiator
    To answer your question on spring rate: the units are Inch/Pounds so a "500 pound spring" compresses 1 inch per 500# of pressure applied.
    Based on vehicle weight, and the length of the coil (after it is assembled in the coil-over) ride height is determined. The complicating factor is that coil springs also have a minimum length (when the coils touch, called Coil Bind). This limits the preload we can put on a spring to get ride height.
    As with everything else in suspension, ride quality and performance are a trade off, and making big changes (armor, bumpers, winches) will make a formerly great truck into a dog.
    Redmann[QUOTED] likes this.
  12. Nov 30, 2017 at 3:12 PM
    #8732
    cynicalrider
    cynicalrider #NFG
    Jersey
    Bullshit. Your ome’s don’t cause your tc’s to over extend. Your uca’s do nothing to limit any over extension. Your uca’s would keep dropping if it wasn’t the coilovers stopping it.
    bski22 and Blackout14 like this.
  13. Nov 30, 2017 at 3:19 PM
    #8733
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I had 886s before I had skids and bumpers. It was fine. People act like the suspension won’t cycle at all without the weight.
    Then, when I added bumpers etc., I was good to go without having to redo the lift. Which I did anyway...
  14. Nov 30, 2017 at 3:20 PM
    #8734
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    This works too.
    But, if I have parts, they NEED to be installed immediately. lol
  15. Nov 30, 2017 at 3:25 PM
    #8735
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Unlike welders that must remain in the box
    steele-taco, Arcticelf and Blackout14 like this.
  16. Nov 30, 2017 at 3:25 PM
    #8736
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Thats what I just said... the JBA coil must have no stopper to limit it from going beyond its point of no return causing it to break...
  17. Nov 30, 2017 at 3:31 PM
    #8737
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    No one puts No H in a box.
    So I’ve heard.
    Subway4X4 and Blackout14 like this.
  18. Nov 30, 2017 at 3:40 PM
    #8738
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    And, it’s been out of the box for a while now. Notice the creative bottle placement.
  19. Nov 30, 2017 at 3:40 PM
    #8739
    Subway4X4
    Lloyd
    NY/NJ
    Did you have the 5100's or the OME shocks with those 886's?
  20. Nov 30, 2017 at 3:41 PM
    #8740
    Subway4X4
    Lloyd
    NY/NJ
    Bottle makes a great place to hang the welder's helmet
