Permanent Rausch Creek thread
Discussion in 'North East' started by armyofsquirrels, Feb 27, 2016.
  1. Mar 7, 2018 at 12:43 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    So your bushing mount was steel then? You can't weld Alum to steel and get a weld to work properly unless there is some new voodoo welding I am unaware of.
  2. Mar 7, 2018 at 12:46 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    On my Kings the uniball is in cup taht is machined into the lower. The rod is threaded into the lower for several inches. And the lower is not the weak point. Ever have a shock apart? The threads and nut that hold the valving assembly on to the rod are the weakest point. So if a failure were to occur during rapid extension, that would most likely be the failure point.
    To be honest, I have yet to blow up a shock on this truck, and I have not seen with my own eyes a failure that I could definitively pinpoint the cause of failure. I am by no means a shock or suspension expert.
    Blackout14 likes this.
  3. Mar 7, 2018 at 12:49 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    The shock rods are induction hardend steel. But likely the heims is threaded into the shaft on those too.
    Not familiar at all with the Tundra retrofit though. Hopefully they were valved for Monty?
    ovrlndkull and Blackout14 like this.
  4. Mar 7, 2018 at 12:52 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I have had more shocks apart than I can count. Every week circle track racing I was the suspension guy so that was my job. But like you said for most of what we do it would be rare for a shock failure.
    Got ya I did not realize you were talking about your nes wtuff with welding I thought you were talking about the old broken stuff. The tundy shocks look sweet.
  5. Mar 7, 2018 at 12:57 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    :thumbsup:. Most of the pics of the "stock" style performance replacement shocks the lower mounts look like they are anodized alum. threaded onto the shaft which is why I was thinking that. Looking more closely at the king pics all of them are welded it looks like though.
  6. Mar 7, 2018 at 1:08 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I believe you I just looked through a ton of pics and the Kings all appeared to have welded ends even if they are threaded first then welded that adds some strength to them rather than just threaded.
  7. Mar 7, 2018 at 1:10 PM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Negative. But I’m definitely feeling something different back there. Do you think it’s the dakars
  8. Mar 7, 2018 at 1:45 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Stacking dimes looks like some good TIG welding there.
    stairgod and Blackout14 like this.
  9. Mar 7, 2018 at 3:17 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    More than likely it is the spring compressing into that top overload, causing a rapid increase in spring rate, which makes the ride harsh. I eliminated that overload when I got mine and added the extra thrid leaf. The harsh ride that I had stock was what I was trying to get around.
    I would pull that overload, and then see how it rides. I am betting you will see a huge improvement.
    If it wasn't snowing out, I would ask you for a pic of your leaves so I could see how the springs are static in relation to that overload.
  10. Mar 7, 2018 at 3:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :facepalm: You need a dead blow hammer!
  11. Mar 7, 2018 at 3:37 PM
    bski22
    Rob
    Toyota
    Ugh dude! I am totally not looking forward to yanking these! I told myself I am leaving everything because when I’m loaded up on trips I didn’t want any sag. I guess my cutting and shit is going to be more intense than I thought. I’ll send a pic tomorrow
    stairgod[QUOTED] likes this.
  12. Mar 7, 2018 at 4:07 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    O
    Only one I know that has both overloads in his Dakars is Floyd. And that guy packs more shit in the back of his truck than a Filipino going camping.
    :D
  13. Mar 7, 2018 at 4:38 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Yupper. I’m a boy scout.
    There’s not been a single time when someone I’m wheeling with asks if I had something they needed.
    @Sub-Zero : “I wish we had a 18” x 10” piece of plywood we could set this jack on.
    @Subway4X4 : No, sorry dude. But how about this 18 x 11 instead.
    @HolyHandGrenade : I forgot D size batteries for OCK’s hot shower. I’m fooked.
    @subway : How many do you need?
    @Lux : Lloyd got any superglue to fix my actuator?
    @Subway4X4 : yup, but I think this epoxy is a much better choice. Here ya go.
  14. Mar 7, 2018 at 4:42 PM
    bski22
    Rob
    Toyota
    Gives me something to do. I’ll probably yank it. But not sure I’ve got 500lbs in the rear constant
  15. Mar 7, 2018 at 4:43 PM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    Hey James can I borrow that torch to start a fire?
    Redmann, Blackout14 and bski22 like this.
  16. Mar 7, 2018 at 4:44 PM
    steele-taco
    james
    Jersey shore
    Warn or Smittybuilt winch, any thoughts.
  17. Mar 7, 2018 at 4:45 PM
    bski22
    Rob
    Toyota
    Warn or snotty built how many times you thinking you’re goin to winch. Could buy 3 warns to one snotty
    steele-taco[QUOTED] likes this.
  18. Mar 7, 2018 at 4:46 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    o_O
    Warns are more expensive than smitty!
    bski22[QUOTED] and steele-taco like this.
  19. Mar 7, 2018 at 4:49 PM
    steele-taco
    james
    Jersey shore
    Looks like about a 200$ difference
    And from everything I can find Smitty is about 30# heavier, not sure if that's a good or bad thing.
  20. Mar 7, 2018 at 4:49 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Can I make my wired one wireless yet? Smutty bilt. Xrc 9.5k
    bski22 and steele-taco like this.
