Permatex Black Silicone Adhesive Sealant - low temp cure time? Sealing roof rack bolt holes.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jayhat, Dec 19, 2021.
  1. Dec 20, 2021 at 8:30 AM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    This is the real shit. Everything else is a partial solution.
    Here's the version I was recommended by a roof rack shop: https://www.amazon.com/gp/product/B0000AY6B0
    ernscott[QUOTED] likes this.
  2. Dec 20, 2021 at 5:56 PM
    Jayhat
    Jayhat [OP] Well-Known Member
    Thanks all! Appreciate the advice. I used silicone on my 4Runner roof rack with no issues for a few years until I took it off. I was really more curious about the set / cure times in winter, not so much the longevity of silicone.
  3. Dec 20, 2021 at 6:09 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Then read the tube of silicone and see what it tells you.
  4. Dec 20, 2021 at 6:18 PM
    Jayhat
    Did already man. Doesn’t specifiy. Just says cure time is 24 hrs at 70. Saw many things online saying don’t apply in winter, some people said it didn’t matter, etc. was all over the place.
  5. Dec 21, 2021 at 5:14 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Been using Permatex clear and black adhesive sealant (RTV)for many years on a variety of applications and temperatures in very wet cold conditions. It will cure in 24 hrs. at room temperature but cure time will increase as temperature decreases but will eventually harden. It will not drip, ooze, creep or wash off if left undisturbed. Even when soft as soon as applied, it will prevent water ingress and water actually helps it cure faster. For roof rack bolts, will prevent water ingress as soon as it is applied and as long as it isn't disturbed, it will cure and harden up. If used directly on bolt threads it will act as a sealer as well as a low strength thread locker. Will be no issue using it on your rack!
  6. Dec 21, 2021 at 7:10 AM
    Jayhat
    Awesome. Thank you!
  7. Nov 26, 2023 at 12:44 PM
    GrandTheftAngel
    GrandTheftAngel Well-Known Member
    Angel
    I'm curious about the winter aspect too? Did you ever install in winter and if so did you have to rush it? It's pretty cold here.
  8. Nov 26, 2023 at 12:49 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I used butyl tape myself.
    Gen3TacomaOBX likes this.
  9. Nov 26, 2023 at 1:21 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    3M 4200 is definitely a superior product. 3M 5200 IF you never want to remove whatever you're attaching. it's overkill for this fix imo just due to the cost.
  10. Nov 26, 2023 at 1:36 PM
    GrandTheftAngel
    Angel
    That's cool. I'm curious about the winter aspect. Anyone else install roof racks during the winter? Or do most wait for the summer?
  11. Nov 26, 2023 at 1:37 PM
    GrandTheftAngel
    Angel
    Did you ever end up installing in winter? or did you wait until it's warmer?
  12. Nov 26, 2023 at 5:44 PM
    Jayhat
    I definitely installed around the time I posed this from what I recall, but I don’t remember exactly when. It went fine. I’ve never had any leaks. I just installed and never checked it again. All seems well.
