Persistent Engine Shudder (2001 Tacoma)
Discussion in 'Technical Chat' started by tacoma97, Jan 6, 2011.
  1. Jan 6, 2011 at 4:27 AM
    tacoma97
    tacoma97 [OP] New Member
    New Hampshire
    97 4WD LX
    I have a 2001 Tacoma (6 cylinder with TRD Supercharger). Often when I start the truck the engine will shudder briefly then surge before idling properly. Now and then the shudder is stronger and will trip the CEL. What's weird is there is no code when checked. The CEL will go off after a few starts.
    The shudder occurs mostly when the truck sits for over 6 hours and is worse in cold weather. It turns over strong and runs great but the shudder is getting worse lately.
    Any suggestions would be appreciated.
  2. Nov 3, 2011 at 5:03 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    I am having a very similar problem almost exactly the same. Have you had any luck fixing the problem?
