Persistent misfire in cylinder 4 of the 5vz-fe
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ellendejefferes, Aug 2, 2025.
  1. Aug 2, 2025 at 9:41 AM
    Ellendejefferes
    Ellendejefferes [OP] Noob overlander
    Jeff
    Austin Texas
    2001 3.4L Xtra Cab 4x4 5spd
    Just curious if anyone else has run into a persistent misfire in cylinder 4 of the 5vz-fe, in the ignition system to be specific.
    I had a slight misfire in cylinder 4 when I got the truck in the spring and it gradually got to CEL bad. Narrowed it down to ignition in another post so I swapped all the coil boots, plug wires, and spark plugs; it vanished, and the ocean was finally calm for maybe 2 hours of drive time. Then the idle shudder slowly came back but the loss of power this time is much more gradual. I should also note that plug for cylinder 4 was carbon tracking across the ceramic pretty heavily when I initially changed the plugs. I'll bring it to my buddy's shop and suck up the diagnostic fee in September, but until then, any direction would be appreciated.
  2. Aug 2, 2025 at 9:44 AM
    02hilux
    Planet: EARTH
    Compression and leak down test
  3. Aug 2, 2025 at 9:49 AM
    Ellendejefferes
    Jeff
    Austin Texas
    I did one as one of my earlier steps and everything turned out great
    Black97v6MT likes this.
  4. Aug 2, 2025 at 10:48 AM
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    How about getting a spark plug tester (the little ones with a light that connect in line) and testing cylinder 4, vs cylinders 2 & 6? Might point to an electrical issue upstream causing intermittent spark issues. If you do this I'd pull the EFI fuse first and then it wont fire when cranking.
    Did you use OEM plug wires and coil packs, along with Denso dual electrode plugs?
  5. Aug 2, 2025 at 11:25 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You said you did the coil boots, but no coils?
    Maybe it has a bad coil. Move it to a different cylinder and see if the code follows
    t0p_d0g likes this.
  6. Aug 2, 2025 at 11:52 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    +1 on this!
  7. Aug 2, 2025 at 11:57 AM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    X2
  8. Aug 5, 2025 at 4:31 AM
    Ellendejefferes
    Jeff
    Austin Texas
    my bad I said that wrong I got the three new coils as well, the denso ones to be exact like these:
    https://a.co/d/ceonb77
  9. Aug 5, 2025 at 4:32 AM
    Ellendejefferes
    Jeff
    Austin Texas
    Smart! I’ll have to check this and come back and let y’all know, I used all denso products for the coils, wires, and plugs
    Red_03Taco[QUOTED] likes this.
  10. Aug 5, 2025 at 6:21 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    How many miles? The injectors start to go around 200k. Almost always the misfire issue...
    Black97v6MT, Superdave1.0 and t0p_d0g like this.
  11. Aug 5, 2025 at 8:37 AM
    Ellendejefferes
    Jeff
    Austin Texas
    237116, I had thought of doing the injectors back in April but was told not to since I had found carbon tracking on the ceramic of cylinder 4’s plug.
  12. Aug 5, 2025 at 9:06 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I would do the injectors at that mileage anyway. Have seen enough of them cause a misfire in person, and on here, that it wouldn't be a bad investment. If you have another vehicle then I would remove and send them out for rebuild.
    Ellendejefferes[OP] likes this.
  13. Aug 5, 2025 at 9:15 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Swap the coil packs and see if it moved.
  14. Aug 5, 2025 at 10:13 AM
    t0p_d0g
  15. Aug 5, 2025 at 10:31 AM
    Blakeus Maximus
    Blakeus Maximus Well-Known Member
    Southwest
    2000 TACOMA TRD 4X4
    I went through all this before as well. I replaced the plugs, wires and coils packs and boots with all OEM. Still had misfire. I have a friend at a Toyota dealer and they advised to check the compression just to make sure there werent bigger problems. That checked out fine. I had new fuel injectors installed and problem is gone. All this about 40k ago when my truck had 212k on it. 257k on it now and it purrs, I drive it almost every day.
  16. Aug 6, 2025 at 4:11 AM
    Ellendejefferes
    Jeff
    Austin Texas
    OK! I'll do injectors and valve cover gaskets all together then. I'll do it in September.
    With that in mind I've seen this thread before:
    Injector PSA: V6 3.4L 5vz-fe 1st gens | Tacoma World
    Where FRgeoff says you can use these:
    Lexus Toyota RX300 Avalon Highlander Camry Injector 23250-20020 (S6)
    Lexus Toyota RX300 Avalon Highlander Camry Injector 23250-0A010 (S6)
    or the denso fuel injectors like these:
    Enhance Performance and Reliability with 5VZ-FE Fuel Injectors | MotorWest Performance
    So I'm curious if anyone has any thoughts on this route for fuel injectors? I want good parts for my taco but I also don't want to just break bank in the name of OEM when I could get the same product if not a better one for a much nicer price. Just like getting the denso coils and wires instead of Toyota OEM ones when they are basically the same.
  17. Aug 6, 2025 at 6:07 PM
    t0p_d0g
    When complete come back and let us know the outcome.
  18. Aug 7, 2025 at 12:48 AM
    veleno
    veleno Well-Known Member
    From your links it looks like the injectors from MotorWest Performance is the way to go especially with the lifetime warranty.
    I'm currently going through this with a misfire in cylinder 1 so your info above has come at the right time!
  19. Aug 7, 2025 at 1:12 AM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    Go with MotorWest
  20. Aug 7, 2025 at 1:51 AM
    veleno
    :thumbsup:
