Persistent Trouble Code P0125
Discussion in 'Tundras' started by dispatch789, May 22, 2016.
  1. May 22, 2016 at 10:00 PM
    dispatch789
    dispatch789 [OP] New Member
    Tim
    2002 Toyota Tundra; 4.7Ltr V8, SR5 Access Cab, Rear Wheel drive (4 X 2):
    I have a persistent Check engine code of P0125 that keeps coming back even though I have recently changed both of the CATs, all four O2 sensors, the air filter, the serpentine belt, the Electronic Temperature Sensor, and the thermostat. I need to get it to pass inspection for State of Massachusetts next month and I'm told they will not pass it with a check engine light on.
    Anyone else have any ideas of what to check or do next??
  2. May 22, 2016 at 10:01 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Change spark plugs?
  3. May 22, 2016 at 10:02 PM
    dispatch789
    Tim
    Already done that too. :(
  4. May 22, 2016 at 10:04 PM
    dispatch789
    Tim
    It had only the P0125 code for a couple of trys and then the P0155 came up for the B2S1 sensor. So I changed that to a "Genuine Toyota" part and it came back again. This is starting to really piss me off. >.<
  5. Jun 21, 2016 at 9:49 AM
    Nor7
    Nor7 Well-Known Member
    Eric
    Texas
    2011 Tundra, Texas Edition
    4.7L V8 VIN - Auto
    Trouble Code: P0125 (4.7L V8 VIN - Auto)
    Insufficient Coolant Temperature For Closed Loop:
    Print this code data[​IMG]
    Number of Trips to Set Code: 1
    • CCM Details
    • MIL Details
    Trouble Code Conditions:
    California Models DTC P0115 and P0116 not set, engine started, ECT sensor more than 140 degrees F, vehicle driven to a speed of 25-62 mph at an engine speed over 1500 rpm, throttle valve not fully closed, and the PCM detected the A/FS or HO2S signal (internal value) did not change. Federal Models Engine started, ECT sensor more than 140 degrees F, vehicle driven to a speed of 25-62 mph at an engine speed over 1400 rpm, throttle valve not fully closed, and the PCM detected the HO2S-11 input did not exceed 450 mv at least during a test period of 1.5 minutes.
    Possible Causes:
    • * Check the operation of the thermostat (it may be stuck open)
    • * ECT sensor signal circuit has high resistance
    • * ECT sensor has failed
    • * Inspect for low coolant level or an incorrect coolant mixture
  6. Jun 21, 2016 at 9:49 AM
    Nor7
    Eric
    Texas
    Trouble Code: P0155 (4.7L V8 VIN - Auto)
    Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    When heater operates, heater current exceeds 2 A (2 trip detection logic) Heater current is 0.2 A or less when heater operates with +B > 10.5 V and < 11.5 V (2 trip detection logic) Heater current is 0.25 A or less when heater operates with +B ≥ 11.5 V (2 trip detection logic)
    Possible Causes:
    • Open or short in heater circuit of heated oxygen sensor
    • Heated oxygen sensor heater
    • ECM
  7. Jun 21, 2016 at 9:51 AM
    Nor7
    Eric
    Texas
    Hope this helps, not sure if you already got it sorted out.
    You should join us over at Tundras.com, I would have seen it sooner. I rarely log into TW anymore.
  8. Jun 21, 2016 at 10:00 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Neither the OP, who hasn't been on TW since May 23rd.
