Persistent water leak OR how Poseidon himself unleashed his wrath on my carpet
Discussion in '1st Gen. Tacomas (1995-2004)' started by t3hWIT, Feb 9, 2013.
  1. Feb 24, 2013 at 5:30 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Thanks-good write up-that will help everyone with the same problem!
  2. Feb 27, 2013 at 6:28 AM
    kevinray13
    kevinray13 Taco 4 life!
    Kevin
    Lafayette, LA
    07 prerunner TRD Sport
    Billet grille, billet vallence on front bumper, blacked out taillights, l.e.d. lights throughout interior, and blacked out windows
    Red Angel A/C Stop Leak & Conditioner repairs common leak points in automotive A/C systems. Activated at the leak point only, Red Angel will not crystallize with existing oxygen or moisture in the system. After repair is achieved Red Angel will continue to lubricate and condition working parts.
    Product Features:
    • <LI type=disc>Permanent repair for condensers, evaporators, connections hoses, gaskets, and O-Rings <LI type=disc>Contains no solid or particulate matter that will clog an A/C system or harm recovery units <LI type=disc>Activated by airflow only at the leak point
    • Gets reclaimed with oil and will not clog or damage any part of the recovery unit
    Does anyone know if this will help my leak? Or has anyone else tried a product like this?
  3. Feb 28, 2013 at 4:39 AM
    t3hWIT
    t3hWIT [OP] Well-Known Member
    Wit
    Central PA or wherever the wind blows me
    Rusty '98 Tacoma
    Why hijack my thread on a water leak to post about your A/C refrigerant leak? This is not the appropriate thread for that question.
  4. Mar 10, 2013 at 10:29 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I'm having the same problem with my 2nd gen, thanks for the thread OP its giving me some good starting points!
  5. May 26, 2013 at 9:59 AM
    HOD
    HOD Member
    PA
    03 Taco
    You might want to sacrifice at least one bull at the local temple, preventatively. I'm not sure the gods look favorably at the hubris of trying to repair Poseidon's works yourself.
    I always have the oracle predict any maintencance issues in advance. For instance, I know that I'll need to do another oil change in 3,000 miles.
  6. Jul 20, 2014 at 9:52 PM
    Bino9905
    Bino9905 Well-Known Member
    TX
    99 ExtCab 4X4 V-6 TRD
    I have the same issue on my 99
    My carpet is completely soaked.....
    The previous owner was into car audio.....I found at least 20 drill holes in cab floor.....holes were to hold amps and act as ground.....I ripped all that crap off
    I used job weld to seal all the holes
    Since I had removed all carpet and seats I decided to sit inside and have my wife use water hose all over while I checked for leaks
    Found a big one on fire wall.....he ran a huge power cable for amp and pushed grommet out the way.....water came in......that one was an easy fix......
    Now I see the water dripping into the floor right below the speaker on the door
    I pull panel off and water is between door and vapor barrier and dripping into cap....like it's going in around the speaker...
    OP can you please post the pics again.....I could only see some of them.....the ones with arrows don't show up.....thanks and I hope I cAn also win this battle.....hope stealer ship does not want too much for vapor barriers....is there other material to use.....where did u get that black putty tape from?
    Thanks
  7. Jul 26, 2014 at 8:33 PM
    Bino9905
    TX
    We'll I ended up using dynamite all over the door and the leak is gone!!
  8. Jul 26, 2014 at 8:33 PM
    Bino9905
    TX
    Dynamat
  9. Jul 27, 2014 at 1:22 AM
    cmj
    cmj Well-Known Member
    Tucson
    98 Tacoma 4x4
    Floor is probably gone too
