Personal experience with Toyo Open Country AT3 vs BFG KO2
Discussion in 'Wheels & Tires' started by SendtheFire, Apr 7, 2023.
  1. Jul 3, 2024 at 5:37 PM
    lessgoo88
    lessgoo88 Well-Known Member
    2019 Tacoma TRD Off-Road Cav Blue
    King 2.5 Coilovers, Cab Mount Chop, 33’s, Lights.
    Love my K02's! much better grip for on road use but it depends on what the end goal is for the truck
  2. Apr 5, 2025 at 10:52 AM
    NVbirddog
    NVbirddog New Member
    2008 Tacoma Double Cab 4x4
    Hey everyone,
    Figure I’d post this question here since it’s about these tires specifically. I do A LOT of off roading. Constantly in and out of rough roads in Nevada, on construction sites, and anything in between. I put the Toyo AT3’s on my 2008 Tacoma in November. Maybe I’m just having bad luck, maybe it’s just because I drive near construction, but I’ve had four punctures requiring patches in my front tires since mid December. It’s frustrating, seems excessive as I do try my best to be careful and avoid glass, trash, etc.
    Should I be switching these out for a burlier tire like KO2’s? With more ply? And also, if I do, would I just eat the cost of my Toyo’s which only have 10,000 miles on them, or can I sell them somehow. Thanks
  3. Apr 5, 2025 at 10:54 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    What size and load did you go with?
  4. Apr 5, 2025 at 11:01 AM
    NVbirddog
    265/65R17 116T
  5. Apr 5, 2025 at 11:06 AM
    BLtheP
    Plano, TX
    You might have better luck with a KO2/KO3 since they are all LT only, but it’s probably luck more than anything. I’ve had numerous sets of Toyos both LT and SL/XL, and no puncture problems. Meanwhile my brother put KO2s on his tundra and had multiple nails in 2 of them. So really nothing is resistant to punctures, although if the nails are short, then a BFG may not be punctured enough to lose air whereas the thinner XL Toyo might. Other than that, they’re both rubber and will both puncture.
    NVbirddog[QUOTED] likes this.
  6. Apr 5, 2025 at 1:54 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    No matter how hard you try to avoid hazards on a construction site it is a losing battle. I would avoid driving on the construction sites and use them until there worn out.
  7. Apr 5, 2025 at 5:36 PM
    NVbirddog
    Don’t have the luxury of avoiding them, I work in them
