Pesky P0420 trouble code
Discussion in 'Technical Chat' started by travisdean54, Feb 24, 2013.
  1. Feb 24, 2013 at 12:28 PM
    travisdean54
    travisdean54 [OP] Member
    Travis
    Camden, NC
    12 Trd Sport Long bed
    I still own my first Tacoma (2000 4wd 2.7L) with 261k. Every 2 years or so I get a check engine light and its always the P0420 code (catalyst below threshold bank). I've changed o2 sensors and it takes care of it for a while. I'm thinking its the converter going bad but the truck has the CA emissions package on it and there are 2 converters. Has anyone else had this problem and if so what did you do to fix it? Any help is greatly appreciated.
  2. Feb 24, 2013 at 6:37 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    My MAF sensor was gunked up from the K&N, also welcome to the forums I'm from currituck
  3. Feb 24, 2013 at 10:06 PM
    01kingtaco
    01kingtaco Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
    Had a exhaust leak fixed the leak no more code
  4. Feb 25, 2013 at 8:10 AM
    BamaToy1997
    Bill
    Navarre, FL
    You are definitely looking at a possibility of a bad catalytic converter. Getting 261K miles on one is not a bad lifetime for it. Do you have a scan tool that will give you live data? If so, look at the graph for your post cat sensor. If it is jumping up and down like the pre cat sensor, then you are looking at a catalytic converter that will need to be replaced, assuming that you have replaced both sensors and that there are no air leaks in your exhaust system.
  5. Feb 25, 2013 at 10:04 AM
    travisdean54
    Travis
    Camden, NC
    I've replaced both O2 sensors a couple of times. I've even replaced the #2 cat since I have two on this truck. I'm gonna crawl underneath and. Check for leaks again but maybe it's just time to replace the cats.
