Phoenix AZ 2017 Tacoma Off road 4x4 DCSB
Discussion in '3rd Gen Tacomas For Sale (2016-2023)' started by Jeffaz1, Feb 6, 2019.
  1. Feb 6, 2019 at 8:28 PM
    Jeffaz1
    Jeffaz1 [OP] Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    I'm selling my 2017 silver sky metallic Tacoma TRD Off Road 4x4 DCSB with 43,000 miles. Has tech and premium package, safety package, BFGoodrich KO2s and matte black TRD alloy wheels, Pro grille, hard tonneau cover (was $800 new), windows tinted, badges painted matte black, TRD Off road hood decal, LED headlights, LED fog lights, all interior lights are LED, just installed a new battery and cabin air filter. Very well maintained, always garaged, always hand washed, non smoker. Sticker was close to $40,000. Asking $31,000 (make offer).
  2. Feb 7, 2019 at 12:48 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    There are some other guys on here with more mods, less miles right in the low 30’s too, can you go lower?
  3. Feb 7, 2019 at 2:50 PM
    Jeffaz1
    Phoenix, AZ
    $31,500 is the high end of KBB private party when I entered all the info in, and I thought my truck justified it, but like I said, I am open to offers.
  4. Feb 7, 2019 at 2:57 PM
    Overland&UpMoutains
    Parker
    Deleware
    Yea I saw that I was thinking on the other side of KBB. I am just putting out feelers at this point and just trying to see what everyone is open to.
  5. Feb 7, 2019 at 8:03 PM
    alexplb
    alexplb Well-Known Member
    it depends, a quick search and you can find lower miles for same or lower price with mods :)) good luck w/sale regardless!
  6. Feb 7, 2019 at 11:28 PM
    alexplb
    it don't matter to me private or not CA charges tax on private sale all the same... so it really don't matter in this state. But as far as prices go I've seen a spectrum of prices in the last month or so that I've been keeping an eye for. You said you wanted to get feelers and I gave you my opinion no need to be rude about it just trying to give you real world observations made in the last few weeks I've been browsing.
  7. Feb 8, 2019 at 3:55 AM
    Jeffaz1
    Phoenix, AZ
    If it's not for you, then move along. Some people when they buy a used vehicle would rather buy one closer to factory than have a bunch of mods. It depends on the person. And some of the mods can end up being headaches if they weren't installed right or if they break. Of course CA has private taxes, I bet they tax you even if you don't buy the vehicle. Like a test drive tax. There's lots of benefits to buying private in AZ: no sales tax, no add ons, no pressure, none of the usual car dealer tricks.
    TacoBuffet likes this.
  8. Feb 8, 2019 at 4:03 AM
    Jeffaz1
    Phoenix, AZ
    Also, the people selling them for cheaper probably aren't willing to negotiate much, so are they really cheaper than mine?
  9. Feb 8, 2019 at 9:30 AM
    alexplb
    Haha. No kidding ca is a runaway train. She is out of control. But again the advantage is only for those who live in az I can’t buy it and register it in ca without paying used car tax upon registration. Again good luck with the sale it’s a clean looking taco. You welcome for the bump;)
  10. Feb 8, 2019 at 2:15 PM
    Jeffaz1
    Phoenix, AZ
    Thanks!
  11. Feb 8, 2019 at 2:18 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    If you interested in swapping for wheels/tires plus some cash Im in Tucson and can drive up. I have a 19 TRD OR with 2k miles on stock wheels/tires. GLWS.
  12. Feb 8, 2019 at 2:19 PM
    TacoBuffet
    AL
    Its more than fair, I got $32k trade in for my 17 just before Christmas, was that same truck but MGM w/JBL, all stock and 16k miles.
  13. Feb 10, 2019 at 10:34 AM
    StillNotJohnny
    StillNotJohnny Member
    ‘17 Off-Road DCSB
    PM sent. Is your truck still available?
  14. Feb 10, 2019 at 10:39 AM
    Jeffaz1
    Phoenix, AZ
    Yes it is. I have someone from Offerup coming to take a look at it today.
  15. Feb 10, 2019 at 10:57 AM
    Jeffaz1
    Phoenix, AZ
    Here are some more pictures that I took today, as requested...
  16. Feb 10, 2019 at 10:58 AM
    Jeffaz1
    Phoenix, AZ
    And more
  17. Feb 10, 2019 at 10:59 AM
    Jeffaz1
    Phoenix, AZ
    Couple more
  18. Feb 10, 2019 at 11:00 AM
    Jeffaz1
    Phoenix, AZ
    and last few..
  19. Feb 10, 2019 at 11:41 AM
    Jeffaz1
    Phoenix, AZ
    Just had someone give me a deposit for it and agree to buy it.
  20. Feb 10, 2019 at 11:43 AM
    TacoBuffet
    AL
    Congrats, it was priced very well. Whatcha moving on to?
