Phone mount?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EastVanTaco, Nov 28, 2018.
  1. Nov 28, 2018 at 8:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I haven't seen folks put it over there. It would probably block the radio display if oriented anywhere good for the driver.
    At any rate, no matter where you put it, it won't affect the sight line over the hood like a suction cup on the windshield does a bit.
    I'd get a pic in the other vent, but I sold the Un-Holey Mount after I installed the DMM. The pic in Post 10 is a lot lower than my eye level. The Hondo and DMM put my phone in nearly the same spot.
  2. Nov 28, 2018 at 9:05 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    @tonered im not sure I understand blocking the radio. The vent is to the right of the display and would give you full visual of the radio from the drivers seat
    tonered likes this.
  3. Nov 28, 2018 at 9:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It depends on the arm, orientation, and height. For me, setting it up there for any sort of hands free use, it would block the head unit screen. This is why I use the left side.
    Regardless, either the Hondo or DMM will give you a ton of options for mounts and locations.
    Plus not reaching far when hitting Waze alerts or seeing turns on trails needed for me.
  4. Nov 28, 2018 at 9:12 PM
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    71tattooguy and paleh0rse like this.
  5. Nov 29, 2018 at 3:28 AM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    I'll try and snap one today
  6. Nov 29, 2018 at 4:48 AM
    TacoLlama
    R.I.
    2019 SR5 DCSB
  7. Nov 29, 2018 at 5:33 AM
    silasvirus82
    silasvirus82 Well-Known Member
    NC
    3rd Gen Off-Road DCLB
    Hobie Fishing Edition
    I went with a RAM rear view mirror setup and ran an always hot hardwire USB to power the phone or GoPro.
  8. Nov 29, 2018 at 5:46 AM
    barretta
    barretta -
    San Clemente, CA
    '18 White TRD OR 4x4
    If you just want a normal, unobtrusive mount, then this is a really good one. The guy 3D prints them to hang over the top of the plastic bezel on the dash.
    https://www.etsy.com/listing/541443693/tacoma-phone-mount
    I’ve used the same one since I got my truck and it’s great. Nothing is going to compare to those ram mount contraptions when off-roading though.
    jmneill, brymac76, eddie24d and 5 others like this.
  9. Nov 29, 2018 at 6:00 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I agree with making your own mount... It's easy, cheap, and you can make it work exactly like you want. I used T channel, cut to length, paint body color, 1/4 bolt into the ball mount and used an X-grip. I can add other ball mounts easily.
    Edit to add: When bolting to the bezel like I did, I made a small plate underneath to distribute the load and bolted through that.
    STrooper and tonered like this.
  10. Nov 30, 2018 at 12:47 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    That's pretty neat.
    I've been good with my Frankenmount for the past couple of years (see my signature), but with a new phone I find the Nillkin case for the XS doesn't quite work how I want. First, I had to remove one of the four magnets in the Xs case because it was f'g with the Xs' compass. The other is I figured out last night the setup wasn't maintaining phone charge while running Waze and streaming music over bluetooth. Said it was charging but battery level was slowly ebbing.
    Starting to look into other Qi wireless charging options now.
    barretta[QUOTED] likes this.
  11. Dec 1, 2018 at 8:43 AM
    EastVanTaco
    EastVanTaco [OP] Well-Known Member
    2017 super white Trd Sport DCLB
    I might have to go back to the drawing board.
    I forgot to mention in the original post.
    I have a LG G6 with an UAG case.
    The case is not perfectly flat.
    I bought a thing that goes in the cig lighter to charge but then has an articulating arm with a magnet mount.
    I jb welded the magnet to my case and it broke off x2.
    I used a different epoxy. It lasted several months and just broke off again.
  12. Dec 1, 2018 at 8:55 AM
    Boyitz
    Boyitz Well-Known Member
    Baltimore
    2018 TRD Sport 4x4 DCSB Cement
    That's exactly what I have. It's perfect.
    brymac76 and barretta[QUOTED] like this.
  13. Aug 1, 2020 at 5:14 PM
    CourseMotorsports
    CourseMotorsports Member
    3rd Gen Tacoma
    Course Motorsports phone mount
    Z28tranz, nhw544 and H_19 like this.
  14. Aug 1, 2020 at 5:20 PM
    eddie24d
    eddie24d Member
    2017 Tacoma DBCB SB TRD OR 4X4
    I have had the same one for 4 years now. Works great
  15. Aug 1, 2020 at 6:55 PM
    #35
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I love my Taco Garage DSM. Using a short ram arm and quad lock head it is solid. I also have a 180° USB charging cable (hot glued in place). Works perfectly for me switching Pandora channels, since my head unit doesn't have Android auto.
  16. Aug 2, 2020 at 7:43 AM
    #36
    nhw544
    nhw544 Well-Known Member
    2017 Black TRD Sport DCSB
  17. Aug 2, 2020 at 8:38 AM
    #37
    Schlucki
    Schlucki Well-Known Member
    Rich
    North Dallas, TX
    2020 DCLB TRD OR 4X4 Cement Taco
    A growing list of stuff
    Phone mounts are definitely a personal taste thing. I prefer not blocking my view and where I can touch it without even taking my right hand off the wheel
    Using a Hondo mount, a PanaVise offset tipper, and the holder that comes with my Supcase Unicorn Beetle for my phone.
  18. Aug 2, 2020 at 8:45 AM
    #38
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Santa Cruz Screaming Hand. Classic brings me back to Highschoil skating the Santa Cruz Ditch
    minium[QUOTED] likes this.
  19. Aug 2, 2020 at 8:46 AM
    #39
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I just picked up the 67 Designz. Waiting for delivery.
  20. Aug 2, 2020 at 8:51 AM
    #40
    Hank Heel
    Hank Heel Well-Known Member
    WA
    How is it possible with 4x4 actuator being there?
