Phone Number for Toyota Engineering? Plano, TX?
Discussion in 'Technical Chat' started by 04tacoma trd, Nov 2, 2018.
  1. Nov 2, 2018 at 1:00 PM
    04tacoma trd
    04tacoma trd [OP] Well-Known Member
    Does anyone have a phone number for Toyota's Engineering Department? I believe they are now located in Plano, TX, having relocated from CA a few years ago.
  2. Nov 3, 2018 at 6:30 AM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
  3. Nov 3, 2018 at 8:13 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Plano Texas is corporate headquarters, recently re-located there from Erlanger, Ky.
    Styling is at Calty in California.
    Vehicle engineering occurs at Toyota Technical Center in Saline, Michigan and Japan (Toyota Tech Ctr in Toyota City, Aiichi Prefecture)
    Manufacturing Engineering is still at Erlanger
  4. Nov 3, 2018 at 8:31 AM
    04tacoma trd
    Thanks, I did call the 800 # yesterday and they refused to give me the phone # for engineering. If you have a technical question you are supposed to go see a dealer. If the dealer has no clue you are SOL. I did ask my question with two dealers and they did not have an answer and they claim they have no number they can call when they have no answer for their own questions.
  5. Nov 3, 2018 at 2:38 PM
    stefanlg55
    stefanlg55 Toyota Master Technician
    2008 Tacoma TRD OffRoad
    Whats your question? Unfortunately in order to speak with an engineer you have to be a dealer technician and there is a procedure as well most of the time even as a tech you dont talk to them, only on very technical conditions.
  6. Nov 4, 2018 at 6:17 AM
    mhornco
    mhornco Well-Known Member
    Post your question here and we can give you some really unique answers
    honda50r likes this.
  7. Nov 4, 2018 at 9:52 AM
    04tacoma trd
    Just from time to time I run into things that need a better answer. For example, my current question centers around trying to get Toyota p/n's for pieces for their kits I have purchased. As an example, here is the front sheet for the trailer hitch kit. Note that Toyota does have a bill of materials (BOM), but they just give an alpha description and they do not provide the actual p/n's. I want Engineering to pull the print for the kit and give me the BOM.
  8. Nov 4, 2018 at 9:10 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    It's possibly toyota parts can get you part numbers but the kit you are asking about is one single part number and they dont give individual numbers for each part since youve already bought the set.
    Not to be mean but customers do not get phone numbers for anyone useful above the dealership.
  9. Nov 4, 2018 at 9:12 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    People can't get their transmission fluid checked properly ... adjust your expectations accordingly.
  10. Nov 6, 2018 at 5:50 AM
    Wsidr1
    Indiana
    @04tacoma trd
    Part numbers are kind of a complicated subject. People who work at dealerships, like @Empty_Lord will back me on this one. I can give you some info on your question, but a little background is needed first.
    When Toyota builds a new vehicle, it is sold before it leaves the building at the manufacturing plant. Another branch of Toyota, lets just call them marketing, takes ownership. Any parts installed after that are called by various names like "dealer options", "TRD parts", "post production accessories", etc. Those parts were not designed or tested by the Toyota Engineering Grp you were trying to reach. They would not be able to "pull the print" as you said, and get any sub-component parts.
    I could be wrong (it's happened before!), but I am pretty sure by seeing the kit part number you show, that is not a part that can be ordered so that it is installed IN THE FACTORY. It might be installed before your vehicle gets to the dealership, or at the dealership, but either way, the engineers would not have the info you want. The company that designed the part, and sells it to Toyota marketing would be the only ones. Those part numbers would not be able to be ordered from Toyota unless they happened to be used on some other component of the truck.
    Depending on who sold you this part, I'd ask them how to contact that company to try to get part numbers. As I said, a Toyota vehicle may have the same bolts, nuts, whatever, but it would just be coincidence.
    Wyoming09 likes this.
  11. Nov 6, 2018 at 5:57 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
  12. Nov 6, 2018 at 8:16 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    A dealer might be able to get the part numbers for the repair parts of the kit. It’s under the asg tab in service lane in TIS. If I get a chance today at work I’ll see if I can get you some part numbers. Might not be there but I can try
    What year is the truck
  13. Nov 6, 2018 at 3:47 PM
    04tacoma trd
    Interesting information, guys. Thanks. I purchased the kits from a Toyota dealer (I did ask about the component p/n's years later and they did not know). The truck is a 2004.
  14. Apr 26, 2019 at 7:12 PM
    tbelt
    tbelt New Member
    Tim
    Indy
    19 TRD O/R + 03 TRD
    Truck Nuts, K+N Filters, Lots o’ Stickers,
    Engineering isn't the department you're looking for. Combined packages and components would likely be marketing or sales..
