photos from photo bucket
Discussion in 'Audio & Video' started by pa blaster, Feb 16, 2012.
  1. Feb 16, 2012 at 4:43 PM
    pa blaster
    pa blaster [OP] Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    :confused:heres the deal i got some awsome picks to post but i cant for some reason.....it says error creating resized medium image
    error code 1
    command
    ''usr/local/bin/mogrify''quality 70 geometry 600x450/home/tacoma/public...html/gallery/data/500/medium/o00972.jpg
    any help would be nice
    :frusty:
  2. Feb 16, 2012 at 4:48 PM
    Aw9d
    Aw9d That one guy
    Open your album, copy the IMG code link..
    or add this to the front of your url [​IMG]
    example
    [​IMG] (remove the spaces and make it all one long word. and for a test used this picture from my photobucket http://i885.photobucket.com/albums/ac60/aw9d/Need_For_Speed420.jpg
    When you remove the spaces you get this
    Hope that makes sense, had a few to drink.....
  3. Feb 16, 2012 at 5:58 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yup... each of your photos on photobucket has some links below them... use the IMG Code link to paste photos here. When you upload to Photobucket from your PC, click on 'Upload Options' (in small blue text below the box that appears to download images), and select a reduced size so as not to stretch the thread off the monitor! 800 pixels or the next one smaller is the biggest you want to use on forums, usually.
  4. Feb 16, 2012 at 6:12 PM
    pa blaster
    Scott
    central pa
    k gonna give it a shot thanks it will be alittle bit
  5. Feb 16, 2012 at 7:07 PM
    pa blaster
    Scott
    central pa
    this is what i came up with
    http://i1070.photobucket.com/album
    what the hell do i do with it?????? that is my test photo of my smashed rear bumper (suppose to be anyhow
  6. Feb 16, 2012 at 8:48 PM
    pa blaster
    Scott
    central pa
  7. Feb 17, 2012 at 5:43 PM
    David K
    That is the ALBUM link... and not even a Photobucket album! You need to be in YOUR Photobucket album and on the PHOTO page(s)... Under each photo are about 4 links (or what you customized it to show). The bottom link is called IMG Code... Use your mouse and copy that link... the paste it here on the forum where you type your posts. You can put up several pictures (good to double space between them)... and you can add captions for each, as well.
