Phx emissions- what passes and what doesn't?
Discussion in 'Arizona' started by CurboCycles, Aug 20, 2011.
  1. Aug 20, 2011 at 10:11 PM
    CurboCycles
    CurboCycles [OP] Well-Known Member
    Curtis
    Phoenix, AZ
    BLACOMA
    AFE CAI, Flowmaster muffler, Donahoe Racing 2.5" Coilovers, all-pro 3" leaf springs, 5100s, 17" Method wheels, 285 Terra Grapplers, Avid step bars, scooped hood, painted bumper, debadged, black grill and Toy symbol.
    I'm weighing the benefits of headers (short vs long tube) and y pipes. Here in phx, how strict are emissions testing? Do both kinds of headers pass emissions here or do they have to be returned to stock? What about aftermarket y pipes?
  2. Aug 21, 2011 at 8:23 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    All I remember they are really strict on gas engines.
  3. Aug 21, 2011 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    As long as your not throwing any engine codes, you'll pass.
  4. Aug 21, 2011 at 8:29 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This.
    They just plug into your OBDII port and scan for codes and readiness monitors. As long as those pass then it's good to go.
  5. Aug 21, 2011 at 11:08 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    But don't clear it with one of those
    scanner tools, my friend did that before and they knew somehow,
    said they couldn't read it correctly at the time and made him come back,
    so he cleared his computer out by unplugging the battery to reset and that worked.
  6. Aug 21, 2011 at 11:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you clear the code, then shut the truck off, and turn it on again, and no code shows, then you will pass. If you clear it while running, and go thru emissions, then it will fail.
  7. Aug 21, 2011 at 11:11 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Aha good to know lol I'm going to go laugh at him now!
  8. Aug 21, 2011 at 11:24 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    I have long tube headers and the 02sim and am fully confident in passing emissions when the time comes
  9. Aug 21, 2011 at 1:16 PM
    CurboCycles
    Curtis
    Phoenix, AZ
    BLACOMA
    Great feedback. So if i understand correctly, lt headers will throw a code unless you have o2 sims. Short tubes and y pipes don't throw codes, correct?
  10. Aug 31, 2011 at 3:18 AM
    Trapper6speed
    Stock
    I guess the o2 sims make them pass. I had a diesel when I lived there really no probes there.
  11. Sep 7, 2011 at 4:52 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    yeah, they check odb2, and that you have a fitting gas cap for any odb2 vehicles, its great :D
  12. Sep 7, 2011 at 7:04 PM
    SGT Taco
    SGT Taco Disco Disco...
    Scott
    Rio Rancho Nm.
    R.I.P. 2007 TRD... Now a Land Rover Disco II
    Wife rolled it 3x mod...
    if you have any problems after the install with poping codes, let me know. I can figure out what sensor is poping it and we can get a value of resistance that is with in proper range and solder that in place so that your ECM thinks it is good to go. Have done this many times up in IL for when people mod there cars. more over we could run the wire into the cab and hook up a potentiometer so that you can "tune" that sensor input on the fly incase you pop a code later, but that is a bit much...
  13. Sep 7, 2011 at 8:10 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    your like an electrical genius :D ive still not fixed that horn. considering air horns.
  14. Sep 8, 2011 at 11:17 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I am emissions certified in AZ (but only for fleet vehicles so I cant test you). The law says that you also still have to have all emmision related components as well. IE if your truck came with a CAT, EVAP, etc it must still have it. They are supposed to check but I did my truck last friday at a state inspection and they didnt pop the hood or look under the truck.
    Also you cant just clear the code and start the truck and assume your ok. The MIL light only comes on after you have had the error for 3 consecutive drive cycles. To be a "drive cycle" your computer has to get a ready status from all inputs (coolant and o2 sensors up to temp, etc) and your truck would have to be in closed loop.
    I actually have to go in for my yearly re-certification in about 2 weeks. I can ask the specific question if you want.
  15. Sep 8, 2011 at 5:31 PM
    SGT Taco
    Scott
    Rio Rancho Nm.
    Thank you... this- mod day coming up i will bring all my electrical tools, and we will get that done.
    Also have you seen that "The best of train horn pranks" on youtube?
    http://www.youtube.com/watch?v=icnRMW6P9nc
