Physical Location of Connector/Junction 2A
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoffengineering, May 15, 2022.
  1. May 15, 2022 at 7:35 PM
    hoffengineering
    hoffengineering [OP] Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Does anyone know the physical location of connector/junction 2A as show in the WDs?
    From the FR Fog WD:
    It looks like it's referring to the fuse/relay block in the engine bay, but wanted to confirm.
  2. May 15, 2022 at 8:08 PM
    caribe makaira
    Caribbean, Puerto Rico
    inside 2B is a buss bar linking various circuits.
  3. May 15, 2022 at 8:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Correct.
    hoffengineering[OP] likes this.
  4. May 15, 2022 at 8:20 PM
    caribe makaira
  5. May 15, 2022 at 8:40 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Thanks, I appreciate the answers.
    Which WD page/section is that?
    To confirm, the physical location of the buss bar is at the engine bay fuse box, correct?
  6. May 15, 2022 at 8:48 PM
    caribe makaira
  7. May 15, 2022 at 8:50 PM
    caribe makaira
  8. May 15, 2022 at 8:50 PM
    TnShooter
    Deogee
    STOCK
    What is it that you are doing that requires accessing the wiring at 2A?
    Are you diagnosing an issue?
    Dm93 likes this.
  9. May 15, 2022 at 9:01 PM
    caribe makaira
    Rear of 2A...Fuse/Relay box needs to be opened...
  10. May 15, 2022 at 9:05 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Thanks for the pictures @caribe makaira. That really clears things up. Much appreciated.
    I'm attempting to wire a CH4X4 for light switch in place of the stock switch. I'm trying to utilize the stock wiring--at least the parts of the wiring going to the FR FOG relay and GND.
    Because the stock switch switches to GND, and the CH4X4 switch wants to switch to +12V, I'm running into an issue and exploring options.
  11. May 15, 2022 at 9:10 PM
    caribe makaira
    The "ground" will do what you need it to do with the China Switch...Blue to the switch input, output of switch to ground.
  12. May 15, 2022 at 9:17 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    The only issue that I'm facing is that the top part of the button (the "ON" indicator LED) doesn't illuminate when the button is in the ON position.
    The bottom part of the button (the LED that comes on when the combination switch is in the headlights ON position) illuminates fine and the fog lights are operational.
  13. May 15, 2022 at 9:19 PM
    TnShooter
    Deogee
    STOCK
    Can you give use a link to the switch you have?
  14. May 15, 2022 at 9:25 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
  15. May 15, 2022 at 9:26 PM
    caribe makaira
    Have you tested it? Maybe it's a bad LED in the switch.
    TnShooter likes this.
  16. May 15, 2022 at 9:27 PM
    TnShooter
    Deogee
    STOCK
    You could probably use a separate relay to supply ground to the FOG relay.
    Ground wire to NEW relay, out of NEW relay to the Blue wire of the old foglight switch connector.
    You need to power the NEW relay with the power supply from the NEW CH4x4 switch.
    That’s too much work for me. But it could be done.
    I’m quite sure there is an easier way, but I’m not know for doing things the easy way.
  17. May 15, 2022 at 9:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Why not just use a factory fog light switch? No splicing or wire modification would be required.
  18. May 15, 2022 at 9:44 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    I tested on the bench, with a mock load, and it functioned properly.
    I also tested without a mock load and was able to repeat the behavior I described above.
  19. May 15, 2022 at 9:50 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Yep, there definitely different ways to do it, but at the moment I'm still committed to getting the stock wiring to work (at least until I exhaust my efforts).
  20. May 15, 2022 at 9:51 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Personal preference.
