Physicist required.
Discussion in 'Wheels & Tires' started by Wakecoach, Jul 19, 2017.
  1. Jul 19, 2017 at 5:41 AM
    Wakecoach
    Wakecoach [OP] Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    What is going to hurt MPG more from these two tires. I have googled and searched. But I end up in the JEEP forums. Who knows if they know what they are talking about ?!?
    What hurts more, weight or diameter?
    BOTH Nitto Terra Graps G2
    A larger Diameter tire but that is lighter 43.72lb
    275/65 r18 @ 32.09 in
    OR
    Smaller diameter but heavier with larger road surface.
    286/60 r18 @ 31.46 in Diameter @ 49.3 lb
    ChadsPride likes this.
  2. Jul 19, 2017 at 5:48 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    You need math. Diameter of tire And gearing need to be mathed :notsure:up. Otherwise lower weight tire equals less mass equals better mpg
  3. Jul 19, 2017 at 6:00 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    It's a combination of both. The mass moment of inertia is what you're after. It's a calculation based in the mass and how far that mass is from the center of rotation. This is really only a factor (theoretically) during acceleration. There are other factors such as friction that will effect fuel economy.
  4. Jul 19, 2017 at 8:46 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    If I were to gamble I'd bet the 275/65R18 tires would yield better mpg.
  5. Jul 19, 2017 at 9:15 AM
    tymbo
    tymbo Well-Known Member
    I doubt the difference would be measurable unless under ultra controlled conditions. In the real world, many other variables would have more profound effects on mileage. Bottom line: probably negligible.
    NM Lance likes this.
  6. Jul 19, 2017 at 4:40 PM
    Wakecoach
    Kurt
    Sweet thanks TW. 275s it is .
  7. Jul 19, 2017 at 4:53 PM
    jowybyo
    Joe
    Baltimore, MD
    Sweet.
    PS. Since we are talking physics, the surface area touching road will be the same regardless of the width of the tire (assuming you run the same air pressure in both, which isn't based on width so there's no reason you wouldn't run basically the same air pressure in both).
  8. Jul 19, 2017 at 5:09 PM
    Wakecoach
    Kurt
    For real ? Didnt know that. Appreciate it . Thanks
  9. Jul 19, 2017 at 5:18 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    No physicist required. There's the interwebz. It's just search verbiage that yields results.
    This site can calculate the math and give you most of what you're asking for and more.
    http://hpwizard.com/rotational-inertia.html
  10. Jul 19, 2017 at 5:19 PM
    Wakecoach
    Kurt
    Thanks .. that's awesome
    GPsevinSixx[QUOTED] likes this.
  11. Jul 19, 2017 at 5:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    Taller tire, taller final gear ratio, less fuel used at cruising speeds. Potentially more fuel used if a lot of stop and go driving.
    Lighter tire, in terms of MPG, always the winner. It also helps with ride quality and several other things affected by unsprung weight.
  12. Jul 19, 2017 at 5:32 PM
    Wakecoach
    Kurt
    Great . Awesome advice . Thanks
  13. Jul 19, 2017 at 5:34 PM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    Not true across the board a wider tire has more drag on the road.
    Too many factors. Tread compound. Pressure at volume, heat, deflection of tire itself when forces act on it.
  14. Jul 19, 2017 at 6:28 PM
    jowybyo
    Joe
    Baltimore, MD
    Do you mean more contact friction or more air drag?
    All things equal, a wider tire has the same contact patch area as a narrow tire. The contact patch is a function of the pressure in the tire. Also, friction (traction) is independent of contact area (and pressure for that matter in all but extreme cases). A wider tire could potentially have higher air drag than an equivalently tall narrow tire due to the larger frontal area.
  15. Jul 19, 2017 at 7:01 PM
    blackohio
    Cliche Guevara
    white mudflap
    Load increase on a narrow tire will cause pressure decreases in essence lengthening contact patch (longer or wider contact patch could mean more friction on the road). Deflection of the sidewalls alters these things as well. Two different tire diameters would have different length contact patches even at a given witdth.
    Lots of things to factor and each variance has so many things to consider. I'm not saying as a general rule of thumb the lighter tire wouldn't yield positive results just that there are a lot of additional factors.
    Ps sorry typing from phone at dinner and rushing through thoughts
  16. Jul 20, 2017 at 4:17 AM
    jowybyo
    Joe
    Baltimore, MD
    How would the pressure decrease in the tire due to adding load? The contact patch will lengthen but it will lengthen on a wider tire too. The total area touching the ground will be the same for a narrow tire and a wide tire (at the same internal pressure).
    They will have the same length and same width (since you said they are the same width tire) contact patches, because the total amount of rubber touching the road has to be exactly the same if they are at the same pressure. The friction for the same compound of rubber will be the same.
  17. Jul 20, 2017 at 5:19 AM
    Wakecoach
    Kurt
    This really is getting deep. Thanks guys. What a great site to be a part of!
  18. Jul 20, 2017 at 8:13 AM
    blackohio
    Cliche Guevara
    white mudflap
    again sorry, load increase = volume decrease = pressure increase. however small those changes may be at the given sizes.
    I was talking about contact patch lengths at varying diameters. Where this all gets tricky is side deformation, sidewall height will play into how the contact patch grows/shrinks.
    I didnt read the OP part about same tire. I was talking about different tires the whole time.
  19. Jul 20, 2017 at 8:19 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    in your example the larger diameter tires better mpg not considering air drag
    BUT this puts more truck up into the airstream, so, more drag.
    put down the bong and go drive yer truck
    IronPeak likes this.
  20. Jul 20, 2017 at 1:51 PM
    Wakecoach
    Kurt
    Not sure why u went there .. but they were valid points.. thanks
