Physics question
Discussion in 'Off-Topic Discussion' started by svdude, Apr 12, 2019.
  1. Apr 12, 2019 at 6:46 PM
    svdude
    svdude [OP] Well-Known Member
    jonathan
    Ok, not a third gen subject but neither are a chunk of other posts here. I ask here since I know there's a handful of smart engineers and/or engineer types here.
    I'm getting ready to make a hoist contraption but need some simple physics help to aid in my rigging. Best way to describe by idea is to ask:
    If a beam is suspended by cables mounted to a ceiling (both cables 90* to the ceiling) one cable is 2 ft long and the other cable is 3 feet long. The beam is 5 feet long and weight 50 lbs, cables are attached at the ends of the beam at an even distance from the end of the beam.
    Do both cables support the same weight?
    I haven't put this to paper yet (trying to get my boy to sleep first). However, thinking about the free body diagram for each point on the beam there's a sine and cosine factor for both ends... It makes me think that each cable will have different tensions, right? Or am I over complicating this and of course both cables support 25 pounds each?
    Mtn Mike and hiPSI like this.
  2. Apr 12, 2019 at 6:50 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    No they don’t. Think about if you held the cables yourself. You would be holding the shorter cable with more strength than the longer one.
    I need to find some paper to write the force diagrams on. But that’s a good thought experiment.
    Stocklocker likes this.
  3. Apr 12, 2019 at 6:52 PM
    svdude
    jonathan
    That's what I would think but I kinda wanna know for sure for my design. I kinda like to either experiment with scales to know for sure of work the problem on paper and know for sure that way. It's been 2 years since I have taken physics 2 or a statics class so I have forgotten most of the fundamentals that would help me solve this type of problem.
  4. Apr 12, 2019 at 6:55 PM
    Twitcher
    Twitcher Well-Known Member
    Tom
    2018 TRD Sport
    Both cable hangers will have the same load as long as the suspended load on the beam is equal distance from the cable hangers (or in other words if the load is in the middle of the beam).
  5. Apr 12, 2019 at 6:56 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    If I recall from my rigging days, the vertical weight should be equal to the weight of the beam since the rigging is at 90* to the ceiling.
    hiPSI likes this.
  6. Apr 12, 2019 at 6:56 PM
    svdude
    jonathan
    Let's say the 50 lbs is evenly distributed through the beam.
  7. Apr 12, 2019 at 6:57 PM
    svdude
    jonathan
    So you're saying that both cables are supporting 25 lbs each since they have the same angle to the ceiling?
  8. Apr 12, 2019 at 6:58 PM
    Twitcher
    Tom
    2018 TRD Sport
    Would still be the same tension or load in each cable.
    AxisCab likes this.
  9. Apr 12, 2019 at 7:02 PM
    styk
    styk Well-Known Member
    Greg
    New Brunswick
    Inferno 17 TRD Sport DCLB 4x4
    in-channel vent visors
    Is this a trick question? In general yes but...... if the cables are attached to the beam very close to center, then the short cable could end up with all the weight with nothing exerted on the longer cable other then it's own weight. But it probably wouldn't hang straight down in that case.
    AxisCab likes this.
  10. Apr 12, 2019 at 7:03 PM
    Jaysonn
    Jaysonn Well-Known Member
    Langley, BC, Canada
    2017 Cement TRD PRO
    The shorter cable that has the the beam higher in the air will take more weight/tension then the longer cable. Only reason i can say this is because i do tandem lifts with cranes and the moment i take a load higher then the other crane i pull more weight on my scale and the other crane loses weight.
  11. Apr 12, 2019 at 7:04 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Yes. I if I recall, it’s when you start increasing the angle from the hoist point does it start increasing the strain on the rope or sling.
    If you held a 50lb bar in your hands with your arms straight down and one end attached with a 1’ extension, does it feel heavier?
  12. Apr 12, 2019 at 7:06 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    establish X to the right, and Y up are positive
    Beam angles from lower left to upper right
    the beam is static. no "X" component.
    Figuratively "Cut" the cables. summate "Y" Components; Y1 + Y2 -50 =0
    Assume uniform weight for the beam
    Center of mass is 2.5 feet along the beam from the left end but due to the angle of the beam, this is (square root of 24)/2 from the left end in the x direction.
    Establish that clockwise moment is positive.
    summate moments about the left end of the beam
    {((Square root 24)/2)*50}-{(square root 24)*Y2}=0
    122.47=4.90*Y2
    reaction force Y2=25.0000025 LbF in the positive Y direction
    therefore Y1 = 24.9999975
    Damn near 25 lbs each
    hr206, markm0311 and svdude[OP] like this.
  13. Apr 12, 2019 at 7:07 PM
    arguscanis
    arguscanis Well-Known Member
    rj
    cape cod
    17 Taco trd sport quicksand
    redline hood struts softopper meso pro shift mod stage 2 ebay scoop light mod fang hood vinyl remote start/ 4g anywhere start N2Designs KTJO 4x4 tailgate lock Faux Pro grill DIY Raptor lights Morimoto Amber fog lights Bilstein 5100 front and rear 887s front Dakar Medium Leaf Pack Poly Bushings Ultra Gauge Pro Skid plate SCS f5's Falken At3 wildpeaks Timbren bump stops x4 Meso led mirror turn signals Anytime back up camera SSO rock sliders (linex)
    cant wait for the explanation, cause if its linear pull i cant see how increased length decreases the weight. would this mean that if you shorten your winch cable its load weight changes?
    then again im convinced the big ball lands first
  14. Apr 12, 2019 at 7:08 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    svdude[OP] likes this.
  15. Apr 12, 2019 at 7:15 PM
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    That’s a statics/dynamics problem :thumbsup:. Draw it up and I’ll do the math for ya
    birry and AxisCab like this.
  16. Apr 12, 2019 at 7:16 PM
    markm0311
    2000 Toyota RAV4
    Never mind. He already did the statics. Listen to this guy.
  17. Apr 12, 2019 at 7:17 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I think the issue is the bean is horizontal, the roof anchor pints are at different heights. If the beam is horizontal, cables support the same weight as long as it’s distributed.
  18. Apr 12, 2019 at 7:19 PM
    svdude
    jonathan
    Statics is still physics based, just a department of physics really. I did take physics and statics a while back but forgot most of it. Gonna draw up a diagram and dig out my physics book and make up a couple free body diagrams for each cable and replicate what was said above.
    markm0311[QUOTED] likes this.
  19. Apr 12, 2019 at 7:21 PM
    markm0311
    2000 Toyota RAV4
    This is the best thing I’ve read all day. Good on ya. The math never lies
  20. Apr 12, 2019 at 7:26 PM
    svdude
    jonathan
    Here's a quick drawing of my question...
    Mtn Mike likes this.
