Physics question
Discussion in 'Off-Topic Discussion' started by svdude, Apr 12, 2019.
  1. Apr 12, 2019 at 9:04 PM
    #41
    Skydvrr
    Skydvrr Well-Known Member
    Gilbert, AZ
    Black '17 OR
    Nah
  2. Apr 12, 2019 at 9:11 PM
    #42
    Inferno!
    Inferno! Well-Known Member
    2018 TRD OR Inferno 2/1 Lift 285/70/16 Grapplers
    Here and there....
    Need to know the weight of the cable. The shorter cable carries more tension from the beam, and the longer cable carries additional tension cause of the increased cable mass.
    Registered engineer here: where do I send my invoice? :D
    mynewtoy likes this.
  3. Apr 12, 2019 at 9:26 PM
    #43
    Toyko Joe
    Toyko Joe Here for the pictures
    I've been away from this type of problem for a few years but I think the cables can't be 90* to the ceiling. I think the load would balance between the two connections slightly shifting the beam to the left because gravity is acting on the entire beam.
    Cable on the left would have more tension than the right cable because it's holding the weight of the beam and the force of the different lenth of cable causing the beam to shift towards the left.
    Yellow lines are showing what I think the cables would actually do, blue is the beam and the purple is to show something...
  4. Apr 12, 2019 at 9:51 PM
    #44
    Fuergrissa
    Fuergrissa Well-Known Member
    Devin
    San Jose
    2000 Cinco speed 4x4
    Op in this case, you can neglect the mass of the cable for you situation as the load is small.
    But if your in a windy area, we’re guna have to start considering vortex induced vibrations.
  5. Apr 12, 2019 at 10:18 PM
    #45
    Skydvrr
    Gilbert, AZ
    Black '17 OR
    How close is it to the event horizon?
    Fuergrissa likes this.
  6. Apr 12, 2019 at 10:34 PM
    #46
    hiPSI
    hiPSI Laminar Flow
    Appalachians
    2019 Toyota Tundra 4WD Crew Cab 5.7L Limited with TRD Off Road Package and Cement
    Beyond the Event Horizon....
  7. Apr 12, 2019 at 10:37 PM
    #47
    svdude
    svdude [OP] Well-Known Member
    jonathan
    So I'm going to make a hoisting system for my garage and this problem is to be sure the load stays level. Imagine lifting this beam (weight may be upwards of 200 lbs) using a double or triple pulley system on both ends of the beam and one single cable through both pulley systems. If in the problem I posted, the high side of the beam is essentially the heavy side, then with a pulley system the load will always self level when raising or lowering the load.
  8. Apr 12, 2019 at 10:45 PM
    #48
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    OEM crossbars Predator steps (Yeah, I "dadded" it. What?!...punk)
    This better not be for one of them damn rooftop treehouses we been fighting over...
  9. Apr 12, 2019 at 10:50 PM
    #49
    svdude
    jonathan
    Actually it's for a hardtop on my Jeep. Toyota guys are smarter than Jeep guys so I asked here. Thanks!:thumbsup:
    BillyToy likes this.
  10. Apr 13, 2019 at 12:24 AM
    #50
    Fuergrissa
    Devin
    San Jose
    You don’t understand what you’ve just done. :anonymous:
  11. Apr 13, 2019 at 4:22 AM
    #51
    Skydvrr
    Gilbert, AZ
    Black '17 OR
    It gone!
  12. Apr 13, 2019 at 4:42 AM
    #52
    dweagle79
    dweagle79 Active Member
    Denny
    2018 Blue Tacoma Limited
    Was this one of those Friday Night Posts but for smart people?
    Mtn Mike likes this.
  13. Apr 13, 2019 at 5:14 AM
    #53
    stun gun
    stun gun Squad designated shitposter
    Aaron
    Goondocks, TW
    Tacomas.
    01 glass and long travel, 2017 sr(5)
    In that case, no information received, irrelevant.
    Op. Overbuild it and take a nap.
    hiPSI likes this.
  14. Apr 13, 2019 at 6:11 AM
    #54
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, Custom Car Grille, MESO Ultimate Turn Signal, RIGID fogs, BHLM with LED upgrade, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, DE-badged, TVD blackout kit, Sienna mirror control swap, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal.
    Equilibrium is at the beam level situation. I was just trying to show, by means of example, that the short cable carries the higher load. By taking the example to an extreme, I had hoped to help show that.
    Sometimes that technique is useful in double checking your work to see if the calculated answer for the question makes sense or if there is something else that needs considered.
  15. Apr 13, 2019 at 6:31 AM
    #55
    fatboyfirebass
    If the cables were attached to the ceiling first at "some" distance apart yes. When I did the quick math, there were some assumptions. i.e. Massless cables, true frictionless connecting points, no variation in the weight distribution of the beam, the attachment points in the ceiling were exactly 4.89897...feet apart, the cable lengths were exactly as outlined, no stretch in the cables under load, etc, etc ,etc.
    For application, in the question posed by OP, the results showed that he the difference in tension of the 2 cables was so low as to be considered negligible.
    I say follow @stun gun advice and overbuild it.
    Use cable that is at least rated for twice the load, 2 lengths of cable at each connection, Use 1 size bigger than needed eyebolts, and leave a few inches clearance all around your hard top.
    RocTaco and stun gun like this.
  16. Apr 13, 2019 at 6:49 AM
    #56
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Excellent thread. Time to go to the lab. Who's going to model this in their garage this weekend?
  17. Apr 13, 2019 at 6:54 AM
    #57
    Twitcher
    Twitcher Active Member
    Tom
    2018 TRD Sport
    It doesn’t matter if the cables are attached to the ceiling at 90 degrees or not (even to a sloping ceiling) as long as the cables are plumb. It doesn’t matter if the beam is sloping or not. Gravity loads are completely vertical. If no lateral load is applied (as implied in this case), the beam cannot move laterally. And the tension (load in each cable is identical if the beam load is symmetrical).
    In the case of a tandem crane pick the load can vary because it is almost impossible to keep the cables exactly plumb during the pick.
    I’m a retired structural engineer. This discussion always came up with newly minted engineers concerning sloped bridges or walkways. They don’t slide off their piers because they are sloped.
    birry likes this.
  18. Apr 13, 2019 at 6:58 AM
    #58
    RocTaco
    RocTaco Habitual line stepper
    Pete
    Rochester NY
    2017 Tacoma SR 2.7L 5-spd 4x4
    Agreed.
    If OP really wants to know, mock it up and hang your beam from 2 luggage scales at your desired angle and cable lengths. That'll tell you what the difference is if any.
  19. Apr 13, 2019 at 7:41 AM
    #59
    takoashihaisen
    takoashihaisen Well-Known Member
    island, WA
    2015 AC 4X4 4cyl M/T SR MGM
    successfully installed 3 windshield cracks
    same.
    the torque at the both side is arm length x mass. The center of mass of the the 50 lb bar is at the center of the bar, which is marked as my artistic STAR. Since the center of the mass is located 2.5 ft from the each side and cables are 90 degrees from the ceiling, the effective arm length (single small vertical lines) from A and B are equal. Therefore the torque at the A and B are the same.
    Points A and B will feel the same force.
    I think, if you imagine the infinite length of 50 lb bar, the difference of 2' and 3 ' will be negligible. Without thinking of math or complicated stuff, you can guess same tension at the both sides.
  20. Apr 13, 2019 at 9:10 AM
    #60
    duckytw
    duckytw Well-Known Member
    100% the same tension in the cable on both ends.
