Physics question
Discussion in 'Off-Topic Discussion' started by svdude, Apr 12, 2019.
  1. Apr 13, 2019 at 9:13 AM
    #61
    svdude
    svdude [OP] Well-Known Member
    jonathan
    So for those that say the tension is the same in both cables, at what point is the tension not the same? What if cable A is 5 feet long and cable B is 1 foot long, is the tension still the same?
  2. Apr 13, 2019 at 9:13 AM
    #62
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I agree the tension is the same in both cables regardless of the attitude of the beam as long as it is stationary. I misread the equilibrium comment earlier this morning
    Edit: And not sure what i was thinking about when i responded.
  3. Apr 13, 2019 at 9:32 AM
    #63
    gmiller
    gmiller Member
    G
    Eastern TN
    2019 tacoma trd sport dcsb concrete
    "Righting moment" along with vortex induced vibrations must be considered here.
  4. Apr 13, 2019 at 9:33 AM
    #64
    duckytw
    duckytw Well-Known Member
    When the difference in cable lengths is equal to the length of the beam, then they'll have different tensions.
  5. Apr 13, 2019 at 9:48 AM
    #65
    takoashihaisen
    takoashihaisen Well-Known Member
    island, WA
    2015 AC 4X4 4cyl M/T SR MGM
    successfully installed 3 windshield cracks
    does not matter. still the same. your original post is somewhere between the following extreme.
    5 ft cable and 5 ft cable (horizontal bar) > same tension
    5 ft cable and 0.00000...1 ft cable (vertical bar)> same tension
    Do not worry. I have already considered 14th perturbation theory on this subject.:D
  6. Apr 13, 2019 at 9:53 AM
    #66
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Yes, as long as the cables or at 90 degrees from the ceiling or parallel to each other
  7. Apr 13, 2019 at 11:28 AM
    #67
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Angle to the ceiling doesn't matter it's a pitched roof. Only thing that matters is that the lines are parallel. You could hook one line to a pitched part of a roof and the other to a flat roof overhang and they are still equal. All that assumes the center of gravity is equally spaced between the lines. The flaw in this study is everyone is assuming a beam. You are going to pick up a hard top that isn't balanced. In this case the weight on each cable will shift more toward the cable below the center of gravity in some increasing percentage regardless of the length of the cable. Hope that made sense the way i said it. I am not a physics guy. But i have picked up 20 to 30 18000 to 30000 pound boats with scales hooked to each cable every day for the last 25 years.
    mynewtoy and svdude[OP] like this.
  8. Apr 13, 2019 at 12:33 PM
    #68
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    Hilarious mental wrangling going on here. Now you know how beginning engineering students about to flunk statics feel.
    Free Body Diagram, make one so you can formally understand all the forces involved, and the directions they act in.
    Another Hint: each tension is "unknown". so, take the Sum of the moments centered at the lower string. Then you know the 50lbs or whatever it was of the beam is centered at the center of the bar, a known distance (moment arm) from the lower string. The bar doesn't rotate, it is static, so you know the direction and length of the moment at the upper string.
    This moment - that moment = 0
    Force times distance - another force times another distance = 0
    You know one force, both distances, have one unknown force (the string tension), you know the directions of the force, so solve for the one unknown force with your one equation.
    "what could go wrong?"
  9. Apr 13, 2019 at 12:52 PM
    #69
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    You can never get a straight answer from the damn internet. Is what this thread is.
  10. Apr 13, 2019 at 12:53 PM
    #70
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    This post sums it up nicely
    https://www.tacomaworld.com/threads...s-it-take-to-change-oil.603575/#post-20322906
    stun gun[QUOTED] and Skydvrr like this.
  11. Apr 13, 2019 at 12:57 PM
    #71
    AxisCab
    Dave
    People wanna be handed the answer, w/o doing the math.
    do the math. I tol you everthing you needed to know to do it.
    "Math class is hard," Barbie.
    I know, girl. That's why I'm going wheeling and shooting. see ya
  12. Apr 13, 2019 at 2:34 PM
    #72
    svdude
    jonathan
    I welcome the math, it's all I've been doing for the last 3 years in school. At least this is easy math once a FBD is put together correctly. I just don't completely understand how to interpolate the forces in the -y direction. Since there's nothing acting in the x or z direction, it's all in the -y aside from the normal force in the +y. Since it's all in the -y direction, I just don't know how to calculate how much force is on each cable with the beam at an angle. If the beam was attached to a wall in one point I can tell you many things about it but I am drawing blanks here. I haven't had time to dig into my physics or statics books. I may just wait until I can see my physics professor and have him explain the forces to me.
    There's a lot of smart people here chiming in but there's 2 directions of thought and no math here to prove anything. There was one guy on the first page of this post that posted some math but I don't agree with his approach and I can't visualize his numbers on a FBD.
    Skydvrr likes this.
  13. Apr 13, 2019 at 2:40 PM
    #73
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    The beam in question has a center of gravity in the center of the beam . Therefore no matter the angle of the beam the distance to the lift points remain the same , keeping the load equal at the lift points .
  14. Apr 13, 2019 at 2:42 PM
    #74
    Bleep100
    17 Sport
  15. Apr 13, 2019 at 3:05 PM
    #75
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    In the original post, the CG will be in the center of the beam.
  16. Apr 13, 2019 at 3:12 PM
    #76
    LSUfan1975
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Isn't this what i said but with numbers and stuff?!?! Lol
  17. Apr 13, 2019 at 3:14 PM
    #77
    LSUfan1975
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Sometimes it's the question that's wrong. Not the answers.
  18. Apr 13, 2019 at 3:27 PM
    #78
    Bleep100
    17 Sport
    I didn't have time to read all the replies . I just posted those thinking they might help .
  19. Apr 13, 2019 at 3:40 PM
    #79
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    The CG is offset in that pic because of the angle it's at.
    svdude[OP] likes this.
  20. Apr 13, 2019 at 4:23 PM
    #80
    AxisCab
    Dave
    You missed the bug, haterz!
    If you want to solve this problem, you hafta understand:
    algebra
    sine and cosine
    force as a vector
    Peeps who light up math books are why we can't have nice things.
