PIAA 510 Burnt out...what the heck??
Discussion in 'Lighting' started by Masada, Jul 8, 2010.
  1. Jul 8, 2010 at 5:33 AM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Anyone else have this issue?
    Passenger side went out last month now the driver side?
    They've only been in my bumper for about 8 months, is this normal?
    I know I have the H3 size, but I'm not sure about all the different variation on that bulb.
  2. Jul 8, 2010 at 5:41 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Yeah, mine burned out fairly quickly. Not sure if it was 8 months, but it wasn't long. Mine are also on all the time, so that doesn't help longevity. Also, both bulbs typically burn out within days of each other.
    Any bulb that is "extreme white" or similar don't last as long as a standard halogen bulb. I still use them though because they match the color of my headlight bulbs.
  3. Jul 8, 2010 at 6:16 AM
    Masada
    Taylor
    Laveen, AZ
    that's so stupid...so I'm going to have to replace the bulbs on a yearly basis...
  4. Jul 8, 2010 at 6:48 AM
    larryde09
    Larry
    Rochester, NY
    It mostly depends on how much you use them and what type of bulb you use. My foglights are on whenever the headlights are on, sometimes more, and I probably change them at least once a year. I'm using those Sylvania white bulbs which cost a little more but don't last as long. However, the standard halogens will last longer and are only like $7.
    Furthermore, my PIAAs are mounted in the stock hole. Since they're mounted on plastic, I suppose its possible that they receive more vibration than a stock light that's meant to fit in that hole would, or if it were fitted on a solid light bar/bull bar.
  5. Jul 8, 2010 at 7:11 AM
    Masada
    Taylor
    Laveen, AZ
    I have them mounted in my All Pro bumper, so I don't know if that hurts my situation. I see replacement bulbs from PIAA on Amazon.com for like 5 or 6 bucks, but I don't know if their the right ones.
  6. Jul 8, 2010 at 6:36 PM
    larryde09
    Larry
    Rochester, NY
    1. Your bumper probably provides more support and therefore reduces vibration, so that's probably not a cause.
    2. If it's a reputable dealer, they're probably ok. I think the PIAA website indicates the best bulb...they do offer different kinds and colors. Don't buy them directly from PIAA because they are hugely expensive.
  7. Jul 20, 2010 at 9:53 AM
    jusmac
    jusmac Well-Known Member
    We do offer a 1 year warranty on all of our bulbs. a lot of times on aftermarket bumpers, if you put a nylon washer in between the lamp mounting base and the bumper light tab it will take care of the surging issue that is blowing the lights. give PIAA a call at 1800-525-7422 and if it within a year they will take care of it.
  8. Jul 21, 2010 at 11:53 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    I have 510s in my stock fog location as well, I'm kind of bummed now that they don't last a long time. I paid $200 for them... ugh will see when one burns out!
  9. Jul 22, 2010 at 6:26 AM
    Masada
    Taylor
    Laveen, AZ
    Thanks for that info, I'll try the nylon washer. So I did call PIAA and they told me to call the place I bought them from wich is Got Chrome. Called Got Chrome and they said they would warranty them. I just need to pull them out, I'm being lazzy.
  10. Jul 22, 2010 at 6:35 AM
    mandzach
    mandzach Well-Known Member
    They asked you to pull out the bulbs or the light housing?
    Also, can someone explain the nylon washer / surge fix? How does that work exactly?
    Thanks
  11. Jul 22, 2010 at 6:50 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    heads up!
    Having your 510's mounted in the stock location, heat is also a factor. I washed my truck a hundred times with the 510's out on the light bar but the first time I ran it through with the lights on and in the stock location, I cracked the lens. 2 days later the bulb went.
  12. Jul 22, 2010 at 8:09 AM
    jusmac
    alot of times with lights mounting metal to metal it will create a electrical surge that will blow bulbs. all auto bulbs need to be running at around 13.2amps along with the vehicle. a surge is when you get spikes either up or down in the amperage and is the most common problem is blowing bulbs. lights will tend to ground themselves when mounted to metal bumpers, so if you break that electrical harmony with a nylon washer or something it usually takes care of the surging problem
  13. Jul 22, 2010 at 8:32 AM
    Masada
    Taylor
    Laveen, AZ
    the light housing...
  14. Jun 19, 2011 at 1:49 PM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    I think my driver side bulb just blew after 3 months. The wiring seems fine anyway to tell if its the bulb?
  15. Jun 19, 2011 at 2:06 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Mine burned out also. Just ordered a replacement set of bulbs from Amazon. Like $35 for 2 bulbs i think.
  16. Jun 21, 2011 at 10:11 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    When you got your replacement bulbs the PIAA site says the model is 15455 H3 does it matter if you use an H3 bulb thats different than that? I having trouble finding the H# bulb with that matches 15455.
  17. Jun 21, 2011 at 10:17 AM
    rmb_crew
  18. Jun 30, 2011 at 11:55 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    My bulb finally arrives today, I am going to change it when I get home. Anyone have any tips or tricks or is pretty plug and play?
  19. Jun 30, 2011 at 12:04 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I also swapped mine out with the PIAA plasma ION yellow bulbs to match my figs.
    No, its pretty easy to do, pretty much plug n play.
  20. Jun 30, 2011 at 1:54 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    The old bulb doesn't just pull out where the plastic connection is. Should I just be a limitless rough with it? The buld doesn't even look burned out
